Mills alternative
nduitch
nduitch Posts: 316
edited July 2010 in DIY, Mods & Tweaks
Just ordered 4 of these to replace the polyswitches. They are wire-wound just like Mills and cost 50 cents each. I was going to get 4 more Mills but at 20 bucks and 8 for shipping, I decided to look elsewhere. These were 1.50 total and 3 bucks shipping, no brainer.
http://www.westfloridacomponents.com/mm5/merchant.mvc?Session_ID=b18cacf598d6ac1903670499e41bddfe&Screen=PROD&Store_Code=wfc&Product_Code=WW404&Category_Code=
Post edited by nduitch on
  • audiobilly
    audiobilly Posts: 351
    edited July 2010
    Mmmm, that looks good. Wonder who made these?
  • CTTE
    CTTE Posts: 183
    edited July 2010
    I hope that's not the value you bought. The one you linked to is 3.5K ohm.
  • nduitch
    nduitch Posts: 316
    edited July 2010
    You had me worried, but I just checked my statement and everything is okay, not sure why the link is doing that. Yeah those 3.5Ks would have really toned down the highs.
    redo:
    http://www.westfloridacomponents.com/WW252/5W+.5+ohm+5%26%2337%3B+Power+Wirewound+Resistor.html
  • Face
    Face Posts: 14,340
    edited July 2010
    You get what you pay for, I wouldn't take a chance.
    Besides, those are only 5W, a comparable Mills resistor is only $2 each.
    There are also Mundorf resistors from Madisound, they're cheaper than Mills. https://www.madisound.com/about/resistors.php
  • headrott
    headrott Posts: 5,496
    edited July 2010
    Actually, according to Handamde Electronics Mills resistors are no longer Mills resistors as they were bought out and the orignial Sacramento Mills factory was closed. I posted this link in another thread, but here it is again:
    Greg
    http://www.hndme.com/productcart/pc/viewcategories.asp?idCategory=70
  • Face
    Face Posts: 14,340
    edited July 2010
    Then there's always Duelund resistors: http://www.partsconnexion.com/resistors_duelund.html
    :D
    F1nut Posts: 51,891
    edited July 2010
    headrott wrote: »
    Greg
    Of note, Quality appears to be slightly improved.
    Since they were already great resistors, I simply can't see the point of buying some no name brand at $.50 each when Mills are only slightly more money.
  • skrol
    skrol Posts: 3,456
    edited July 2010
    I would wonder about the inductive characteristics of the cheap-o resistor.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • nduitch
    nduitch Posts: 316
    edited July 2010
    Since they were already great resistors, I simply can't see the point of buying some no name brand at $.50 each when Mills are only slightly more money.[/QUOTE]
    Actually $.38 each, I know you like specificity;)
    skrol wrote: »
    How do you know they are manufactured differently? Have you dissected them and compared? How do you know you just aren't getting charged more because someone stamped a "Mills" on it?
    I'm not anti-Mills or anything, I currently have them installed. Rather than spend 30 dollars to replace 5 cents worth of the poly switches I decided to go with something else. That's why the post it called "Mills Alternative" not "Mills Replacement."
  • Face
    Face Posts: 14,340
    edited July 2010
    nduitch wrote: »
    How do you know they aren't?
  • nduitch
    nduitch Posts: 316
    edited July 2010
    I don't. That's why I'm not saying anything about their quality simply based on their price.
  • headrott
    edited July 2010
    Right Jesse, I wasn't trying to say they were not as good by any means, just that they are not the same "Mills" resistors that people are used to buying. I definately agree that these new "Mills" are better than some off brand resistor and agree that for the price difference, why would you go with a brand you don't know verses a brand name you do. I put two of the new ones into my 3.1TL crossovers and they seem to have great sound. I cannot say if they sound better than the orginal "Mills" or not yet. Just letting people know that they are not the same "Mills" resistors that people have bought in the past.
    Greg
    F1nut Posts: 51,891
    edited July 2010
    I got ya and thanks for posting the info.
    The bold quote was just in case someone didn't click on your link.
  • nduitch
    nduitch Posts: 316
    edited July 2010
    Wasn't every brand a "no-name" at some point? Like everything in this forum someone tries it, likes it or hates it and tells other people. Why make a judgment call on something you have no experience with?
  • headrott
    edited July 2010
    nduitch wrote: »
    Wasn't every brand a "no-name" at some point? Like everything in this forum someone tries it, likes it or hates it and tells other people. Making a judgment call on something you have no recollection of is pointless.
    I think the point is, for a difference of a couple dollars why buy something you don't know if it is good instead of something that you DO know is good. Of course, if there is a $$50.00 price difference and you have a suspicion that the cheaper priced product is as good; it would make more sense to give it a try. Or if you were planning on buying several hundred or several thousand of the resistors it may also make sense. I don't think either situation applies here though. So, I believe that is why F1nut and others have said what was said.
    Greg
  • Face
    Face Posts: 14,340
    edited July 2010
    Well, the description doesn't say that they're audio quality or non-inductive, so enjoy.
    billbillw Posts: 7,689
    edited July 2010
    Kinda confused, but I thought most people just put a jumper wire in when they removed the poly-switches. This is the first that I've read regarding the use of a resistor in its place. I used a simple wire jumper and I do not think that my tweeters run too hot. Perhaps they are only needed in certain speakers?
    On another note, regarding the cheap replacement: One of the main reasons people use Mills is for their 'non-inductive' characteristic. The cheap alternative listed above does not say a single thing about being non-inductive.
  • Ricardo
    Ricardo Posts: 10,634
    edited July 2010
    billbillw wrote: »
    That's how it was done by everyone before we became perfectionists ;)
    SOPA
  • zingo
    zingo Posts: 11,258
    edited July 2010
    Please post your results with the new resistors when you install them.
    I have really been enjoying Jantzen MOX resisitors which I've been told are the same as the Mundorf resistors. I've used them in two projects now and liked the results both times. They may not be as good as the Duelund, but a lot cheaper. :)
  • jrgoswick
    jrgoswick Posts: 159
    edited July 2010
    I like Caddock's myself. HERE!
    Onkyo TX-SR705 AVR
    Onkyo M-501-Given to my father.
    Onkyo DX-C730 CD Changer
    Onkyo DV-BD507 Blu Ray player
    Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
    Polk Monitor 12's with RDO's and XO's
    Polk CS300 Center
    Polk Monitor Series 4 rears
    EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek:
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2010
    Face wrote: »
    100% agree.
