Will my HK AVR 347 be enough?
GMJim
Hello All
I'm glad I found the Polk forum. I'm a real rookie at this and still learning. I've been doing some reading and from what I understand these speakers need more power to sound good than my HK AVR347 can deliver. I'm thinking of upgrading to the HK AVR3600. I was thinking of getting an amp to compliment the 347 but it would cost more than upgrading. I've got a lot to learn. I wanted good speakers when I bought these and the guy at Fry's in San Marcos seemed to be leading me in the right direction but now I wonder if I've bought too much speaker? My room is 25 X 12. Any thoughts?
Jim
Here is a list of my gear.
Panasonic TC-P65VT25 Plasma TV
H/K AVR-347
Polk speakers
Fronts RTi12
Center CSiA6
Surround rear FXi5
Sub DSW PRO500 10"
Panasonic Blu-Ray DMP-BDT350
Any suggestions would be appreciated.
Jim
Jim
H/K AVR-347
Polk speakers
Fronts RTi12
Center CSiA6
Surround rear FXi5
Sub DSW PRO500 10"
Jim
H/K AVR-347
Polk speakers
Fronts RTi12
Center CSiA6
Surround rear FXi5
Sub DSW PRO500 10"
H/K AVR-347
Polk speakers
Fronts RTi12
Center CSiA6
Surround rear FXi5
Sub DSW PRO500 10"
Post edited by GMJim on
The speakers are great.Save up for a good 5 channel amp. Forget upgrading your AVR.
WELCOME TO CLUB POLK!!
There is not much of a difference between those two HK amp sections in terms of real power...either way you NEED a power amp for the Rti-12's & Csi-6--at least!
Save your money and get an amp!
Thanks for the replies!!! I like HK. What would you recommend?
JimPanasonic TC-P65VT25 Plasma
H/K AVR-347
Polk speakers
Fronts RTi12
Center CSiA6
Surround rear FXi5
Sub DSW PRO500 10" -
I'd also spend the money on an amp instead of upgrading the AVR.
What's your budget?
San Marcos, Texas I assume. If so, check the Austin craigslist. Seems like there are always good deals on electronics. Also, audiogon.com
Parasound, Rotel, Outlaw, Emotiva, Sunfire to name a few amp brands. I have an Emotiva and I'm happy with it, but some people have said the RTi/Emotiva combo is pretty bright.Things work out best for those who make the best of the way things work out.-John Wooden -
No San Marcos California but I've recently been transferred to Toronto Canada. I have to upgrade my AVR because of the TV and Blu ray player. It has 3D! I need HDMI 1.4a. The 347 is not upgradable to 1.4a and the AVR3600 is the lowest model with pre outs. Looks like I'll need an AVR and an amp?
H/K AVR-347
Polk speakers
Fronts RTi12
Center CSiA6
Surround rear FXi5
Yes, you'll still want a power amp to get the most out of those speakers. My RTi12s didn't start to open up until I gave them 300 wpc. I'm running 850 wpc into them now, and they sound great.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Jim
You could run the sound separate from the video. Connect the BR to the TV via HDMI and connect the BR to the AVR via optical cable. Not as convenient, but this is what I do and it's not a big deal to me.Things work out best for those who make the best of the way things work out.-John Wooden -
Welcome to the forum.
I am not a fan of AVR's. There are few out there that meet my power needs. I would recomend you buy a used multi channel amp to and use the HK as a preamp only.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
Thanks for all the suggestions and sorry to reply so late. I was away for a few days. I'm a little new to all of this and would appreciate some suggestions on an amp. HK doesn't seem to have one?
I realize power isn't volume but I'm a little confused how an amp will help?
H/K AVR-347
Polk speakers
Fronts RTi12
Center CSiA6
Surround rear FXi5
Could anybody recommend an amp make model and output for these speakers. I know nothing about amps and am having a little trouble finding some information I can understand. Price is a factor but I'd rather spend a little more and do it once.
Any suggestions would be appreciated!
ThanksPanasonic TC-P65VT25 Plasma
H/K AVR-347
Polk speakers
Fronts RTi12
Center CSiA6
Surround rear FXi5
Your best bet is to buy used...go to www.audiogon.com Use their SEARCH engine....select some of the brands PSOVLSK mentions above.....type that in, select AMP...Multi-channel (SS) and see what's available. The rule of thumb is you'd want a 5-7 channel amp that can do at least 200 watts into 8 ohms and 300 or more into 4 ohms.
And the rest is deciding which one and what's your best price and best seller?
Good Luck.
To answer your original question, yes, the 347 is "enough." By spec, it will power all 5 of your speakers adequately. If you're looking for "more," then the above posts leading you toward an amp are the way to go.
Btw, I have found the HK/RTi pairing to be very pleasing - musical even - and it was the fourth AVR I tried in my system. -
Thank you cnh and mdaudioguy
I'll start looking and learn as I go!Panasonic TC-P65VT25 Plasma
H/K AVR-347
Polk speakers
Fronts RTi12
Center CSiA6
Surround rear FXi5
You can always buy a 2 or 3 channel amp to power the fronts (and center), and use the receiver for the rest.
Someone is selling some adcom amps in the FS section for around 250 that should work just fine.
The HK AVR3600 is about 600 dollars, you can probably find amplification for all your channels for that price.
