Custom TV Stand - Charlotte, NC pick up
VR3
This is a long shot - but I built a TV stand back in high school and I am pretty proud of it...
I used solid oak where plywood would not go... and the Walnut panels you see are solid walnut and this is not Lowes purchased stuff - this is the real mccoy, planed down - jointed, sanded, etc etc
It can hold approx 12 or so normal size components...
The middle shelves were designed to hold large amps and preamps
But this is definitely some of the best furniture I have ever built - the finish on it is pretty nice, is could use some 1000 grit + sanding and another coat of poly if you want "furniture grade" finish, right now it looks great until you run your hand on it and can feel the grit of where dust settled on the finish...
I am selling this because I have no room for it at my house and it is taking up some space at my Moms...
Im looking for $150.00 - but I am willing to negotiate I guess - I spent probably three months on it and quite a bit of money...
Here are the two threads with pics and such
http://www.polkaudio.com/forums/showthread.php?t=44267&highlight=stand
http://www.polkaudio.com/forums/showthread.php?t=45619&highlight=stand
Post edited by VR3 on
Eh - I think this will be a little more fair --
100 bucks you take it.
You cant buy a TV stand of that quality at that price period...
Hmmmm- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
How much to ship it to L.A?
Sorry, couldn't resist. lol
Really that's a nice piece of furniture you made there Sid, whoever gets it will be lucky to have it.
Good luck with the sale.2 Channel:
Amp/Parasound Halo A23
Pre/Carver C-1
Tuner/Carver TX-11a
CDP/Jolida JD 100A
Turntable/AR XB-Shure V15 III -
I may take this off your hands. Let me know the dimensions when you get a chance.
Thanks!
Eric. -
Ah sorry man - I donated it to a friend for a college cause
Sorry!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
No problem and thanks anyway. That was one nice piece.
