MIT Cable Fire Sale
13»
  • george daniel
    george daniel Posts: 12,096
    edited June 2010
    pre to amp maybe?
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2010
    I agree with George for the second pair. Audiogon.
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2010
    pre to amp maybe?
    George & Doro
    I am currently using PNF Audio XLR cables there, and bi-amping so I don't have enough for this.. I just changed to these about a month ago. Before that I was using Mono Price XLR cables there.
    The MIT's made a positive difference going from the Oppo to the Pre amp. Is phono pre to pre amp not a good choice??
    Also, does anyone know the input impedance for the Sunfire TGP 5??? I have the cables set to the middle position now.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • dorokusai
    edited June 2010
    It's fine, just an opinion. Put 'em where you can put 'em.
  • vmaxer
    vmaxer Posts: 5,120
    edited June 2010
    dorokusai wrote: »
    I am sure that I will get more in the future as they are very nice. I can't believe how much better they sound!!
    I just need to wait to buy more, unless you have more at that price;)
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • dorokusai
    edited June 2010
    I have to save some things for my goody box.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2010
    vmaxer wrote: »
    George & Doro
    I think that is a good choice. I have a couple of my MITs going from my TT to my phono pre then another pair from the phono pre to the pre. You putting them between the phono pre and preamp is kind of like putting them on your analog source.
    You should be able to find the input impedance for the Sunfire in your user manual spec sheet.
