Am I Awakening Into an Expensive Reality?
Cpyder
Cpyder Posts: 514
edited June 2010 in 2 Channel Audio
So I always listen to my music through my motherboard's optical out. Until recently, when my mobo's sound devices got messed up and no longer work. So I use an M-Audio Transit (USB Device) to output through optical. At least, until I get around to fixing my mobo.
Here's the deal. Both connection types output digital through optical to my receiver but the mobo connection sounds way better. At first, I thought it sounded the same, but after being stuck with the Transit for a while, I notice I get listener fatigue WAY quicker and the highs don't seem as sharp. The music does not seem as real.
Why would this be? Does it boil down to jitter? I have no doubt that my receiver is receiving all of the ones and zeroes in both cases, but the mobo definitely beats the transit. Is the mobo's internal clock just better than the transit's? And I'm assuming that my receiver doesn't reclock so it's timing clock is probably the same as whatever the source is. If it reclocked I would expect similar results in either case.
Am I just now starting to realize that seemingly pointless parameters, like jitter, actually do have very serious impacts?
Post edited by Cpyder on
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited June 2010
    Heh heh........
  • Face
    Face Posts: 14,340
    edited June 2010
    Yes.
  • tcrossma
    tcrossma Posts: 1,301
    edited June 2010
    Cpyder wrote: »
    I'm not sure jitter has ever been considered "seemingly pointless".
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited June 2010
    hehehehehehehehe
    welcome.........its your path.
    RT1
  • TroyD
    TroyD Posts: 13,124
    edited June 2010
    Is it perhaps possible that there are things that affect sound that might not seem all that signifcant? I think that some of us have been trying to tell you guys that for awhile now.
    BDT
  • Cpyder
    Cpyder Posts: 514
    edited June 2010
    tcrossma wrote: »
    No, you're right. But a lot of "legitimate" sources will say that the jitter in well constructed devices is so low that it's effects absolutely cannot be heard.
    TroyD wrote: »
    BDT
    You have been :)
    I'll always be on my search to draw the line on what makes a difference and what doesn't. From coloring your CDs green, to fancy speaker wire geometries, to shielded interconnects, to oversampling DACs, to speaker break-in. Some parameters don't make a different and some do. My quest is to find which does and invest my money there.
    heiney9 Posts: 25,497
    edited June 2010
    Everything Matters - Madmax
    You just have to decide where you are willing to compromise.
  • steveinaz
    steveinaz Posts: 19,546
    edited June 2010
    heiney9 wrote: »
    That's the most intelligent response I've heard around here in a long, long time. You're on it Brock.
  • reeltrouble1
    edited June 2010
    yea this place is full of dumb asses err wait a second:eek:.........not so sure on the words but just words or spin per say, I would say where you wish to begin or prioritize, since it all matters. I do not presently have my 2 channel power situation quite squared away, dont really want to compromise just something on the bucket list for the Rig.
    Thought I lost the entire right channel today after hearing a pop, but looks like a passing gremlin, well, played the rig for about four hours with no problems but for a bit I had no output on one of the mono blocks, switched the amp off then back on............whew looks like a protection circuit may have saved the day.:D
    RT1
  • Flash21
    Flash21 Posts: 316
    edited June 2010
    I had some discussions on this board a year or two ago about how there can possibly be sound differences in digital information transmission, which didn't make sense to me. Based on my limited investigation, it all boils down to jitter.
    Steve Carlson
    Von Schweikert VR-33 speakers
    Bel Canto eVo2i integrated amp
    Bel Canto PL-2 universal disc player
    Analysis Plus Oval Nine speaker cables and Copper Oval-In Micro interconnects
    VH Audio Flavor 4 power cables
    Polk Monitor 10B speakers, retired but not forgotten
  • Cpyder
    Cpyder Posts: 514
    edited June 2010
    Flash21 wrote: »
    That's kind of my thoughts too. I mean, we can prove with absolute certainty whether a device is receiving all of the data of 1s and 0s, but that's not true when it comes to data timing.
