Pair of A9's Price.
k0tuynh
k0tuynh Posts: 144
edited June 2010 in Speakers
Polk direct has a pair of A9's (B stock) for $1009 plus tax & shipping = about $1,200.
Is that a good deal? How good is B-stock speakers from polk direct?
Thanks,
Post edited by k0tuynh on
    Toolfan66 Posts: 18,046
    edited June 2010
    That is how I got mine...
    Great Deal!!!!! You will not notice they are refurbs...
  • k0tuynh
    k0tuynh Posts: 144
    edited June 2010
    Thanks,
    How do you like your A9's ?
    I am thinking of pulling the trigger.
    edited June 2010
  • k0tuynh
    k0tuynh Posts: 144
    edited June 2010
    The A9's are going to be power by parasound hca 2205. Not sure if I'll need a separate sub for 2 channels set up. Currently, I have svs pb10. My room is about 25' x 15'.
  • Ric5811
    Ric5811 Posts: 400
    edited June 2010
    k0tuynh wrote: »
    I dont need one for my A7's, similar square footage. So I wouldn't think you would with those.
    Just give them plenty of time to break in. I bought mine in April, and they just recently broke in. And I use them a lot.
    Polk RTi A7's FrontPolk CSi A4 CenterPolk Tsi 100's SurroundOnkyo TX-RZ50:)Oppo BDP 83 (Collecting dust)MIT Terminator 3 Speaker CableMIT Terminator 2 IC's (Oppo 2 chan)Signal Cable HT TWOEpson PowerLite Home Cinema 1080Hisense 55 U8GBelkin PF 60 Power Center
  • cstmar01
    cstmar01 Posts: 4,424
    edited June 2010
    Also picked up my A9's from there. around the same price and yes for 1200 they are still a good price, may pick them up other places cheaper but probably not in as good of condition and shipping would rpobably be more.
