Looking for creative way to switch on A/V Cooler
SrRaV1981
SrRaV1981 Posts: 8
edited June 2010 in Electronics
Hi, I figured I would post my dilemma here and see if you all had any thoughts. I use an Antec A/V cooler to keep my Amp cool. Without it, it runs pretty hot. My problem is I want to make it so whenever my AMP is on the cooler is on. The Amp does not have a Switched A/C outlet on it. Can anyone think of anyway I could possibly make the fan automatically come on when the Amp is turned on? I would like to avoid leaving it on all the time. It's low power but I don't want it to get clogged with dust..
I know the Amp doesn't have any A/C power out, but I noticed it has an IR/control out on it. My Monster Power HTS 3500 has a D/C input that can be used to trigger its own switched outlets on it. I read both owner’s manuals and started to wonder, if I ran a cable (mono headphone cable) from the Amp's Remote out to the Monster HTS Remote D/C Signal in (mono headphone jack), could that trigger the switched outlets on the HTS ? I know the Amp's remote out is intended to control other Pioneer devices but if it sends any D/C power out, could it be enough to trigger the Monster HTS? The Monster owner’s manual was extremely basic and doesn't say how much voltage it needs in order to trigger the switched outlets.
Any thoughts are greatly appreciated.
Pioneer VSX-919AH 7.1
Panasonic DMP-BD60
Polk CSI3
Polk PSW10
Polk Monitor 70 Fronts
Polk Monitor 30 Sides & Rears
Antec AV Cooler
Vintage Setup:Yamaha CR-2020, Teac A-6300 RtR.
WTB: Optimus Pro Lx-8's
Post edited by SrRaV1981 on
