re-gluing loose surround?
BuckeyeTim
BuckeyeTim Posts: 490
edited June 2010 in Vintage Speakers
Ok, so my buddy that took my S10's is having an issue with one driver. The surround is loose from the frame. Only about 3/4". The rest of it is nice and tight, but this small spot has let go and according to him it is a very noticible change in sound. He can hear that spot "flutter".
What do you guys suggest as a glue and maybe even a method for re-attaching it? It is a small enough spot that it is going to be hard to get glue underneath. I can get a hypo from father-in-law for injecting glue underneath, but what is going to be thin enough to even be able to be sucked up and redistributed by hypo?
Any thoughts or suggestions? The driver for it is not available from Polk and is even kind of hard to find used...otherwise i would just buy him another.
Post edited by BuckeyeTim on
