Can you run a DSW microPRO 2000 with a single Sub woofer preout?
I was just looking at the back of this sub and noticed it had right and left line in RCA connectors. My receiver only has a single sub pre-out. Am I hosed, or will I be forced to use some sort of splitter if I choose this sub?
Optoma HD200x DLP Projector
92" Daiwa Screen
Polk RTiA 7 Mains
Vandersteen 2Ci Surrounds
HSU STF-2 Sub
Pioneer VSX 820 Receiver
Denon DRA-685 Receiver
Denon DCD-815 CD Player
Nakamichi 680 Cassette Deck
Oracle Phonograph
Xbox360 x2
Xbox x2
Intellivision 1
Intellivision 2
Turbographix
SUPER PONG!
One bad **** PC
Home Server
Post edited by aquakenbush on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited June 2010
    Just hook it up to one of the inputs, and you'll be fine.
    It has the left/right inputs for connection to a 2 channel preamp. When you've got it hooked up to an AVR though, using a single input will function as a dedicated LFE input.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • aquakenbush
    aquakenbush Posts: 14
    edited June 2010
    It seems to have two inputs PLUS the LFE input. Which do I use in that case?
    Thanks,
    -Q
    92" Daiwa Screen
    Polk RTiA 7 Mains
    HSU STF-2 Sub
    Oracle Phonograph
    Xbox360 x2
    Xbox x2
    Intellivision 1
    Intellivision 2
    Turbographix
    SUPER PONG!
    One bad **** PC
    Home Server
  • polrbehr
    polrbehr Posts: 2,842
    edited June 2010
    If you're using it mostly in a home theater-type setup, just use a single cable hook up to the LFE input connection from the receivers' sub out jack; L & R won't matter.
  • packetjones
    packetjones Posts: 1,059
    edited June 2010
    +1
    Just use the LFE connection and you will be fine. only need to connect a single cable to the sub.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • aquakenbush
    edited June 2010
    OK. Thanks very much for your responses!
    -Q
    92" Daiwa Screen
    Polk RTiA 7 Mains
    HSU STF-2 Sub
    Oracle Phonograph
    Xbox360 x2
    Xbox x2
    Intellivision 1
    Intellivision 2
    Turbographix
    SUPER PONG!
    One bad **** PC
    Home Server
  • aquakenbush
    edited June 2010
    Thanks!
    92" Daiwa Screen
    Polk RTiA 7 Mains
    HSU STF-2 Sub
    Oracle Phonograph
    Xbox360 x2
    Xbox x2
    Intellivision 1
    Intellivision 2
    Turbographix
    SUPER PONG!
    One bad **** PC
    Home Server
