Computer & parts: HTPC, WiFi NICs, audiophile PSU
doctorcilantro
Atheros AR5895 wireless PCI-E PCI Express full b/g/n w/ 2.4gHz antenna and cable $35 shipped
Intel 5300 w/ (2) premium 5.8gHz antennas and cables $45 shipped
PSILE mini-ITX AMD dual-core - $420 shipped
One of my HTPCs, based around the Jetway JNC81 & AMD 5050e Brisbane. Psile case top fits but snugly due to giant heatsink. I never used the case top as it was in a cabinet, and the case top is a little marked up; you have been notified. 1080P over HDMI is no problem for HD3200 ATI onboard. It will come with a myriad of cables and includes a nice PicoPsu 20pin with AC brick. Has the Panasonic DVD slot-load burner. 3GB of RAM. No hard drive.
Original boxes for Jetway JNC81 and the AMD 45w cpu.
Brand new board from Jetway (I suspected a problem with my IDE connection and got a new replacement just 1 week ago, but they said nothing was wrong with it anyway; see attached invoice)
Audiophile PSU Wimate dc-dc converter & 20V 11A 220W New Genuine Liteon AC Adapter for Clevo D9T (4 pin tip) - $65 shipped for both
This one has the most robust filtering over the PicoPSUs and the my current M10 supply. The included AC adapter is of the highest quality according to the WinMate supplier and was specifically recommended by him. Please see the SPCR review.
- Stock unused AMD heatsinnk
- Slot load Panasonic DVD burner
- JetWay JNC81-LF AM2+/AM2 AMD 780G HDMI Mini ITX AMD Motherboard
- Kingston HyperX 3GB (2GB + 1GB) 200-Pin DDR2 SO-DIMM DDR2 800 (PC2 6400) Laptop Memory Model KHX6400S2LLK2/3G
- AMD Athlon 64 X2 5050e Brisbane 2.6GHz Socket AM2 45W Dual-Core Processor Model ADH5050DOBOX
- psile_10b Psile 10b Silent Black Mini-ITX Case w/ DVD Drive
- PicoPsu 120
- External Power Supply 12V DC 110W
- Scythe Ninja Mini
- 120mm fan
- short 8" eSata cable
- Sata Nexus cable 10"
High quality and high efficiency ATX power supply excellent for HTPC or normal PC up to 130W it also can be used for any other application as a normal DC-DC power converter since it does not need a minimum load.
This is a real 130W power supply and it will work 24/7 at the rated output is designed for industrial automation or medical use and is excellent quality see the photos .
You get the power supply module , power supply cable and ATX 20p cable (it will work on 24 pin MB) as you can see in the last photo .
All photo are from the actual power supply I have more you will receive an identical one new in the box.
Tests done on my computer with my old 275W ATX power supply an this new one that I have listed on ebay.
Computer status Old 275W SFF ATX [Watt] New DD-24AX V220-2 + 180W 24V AC adapter [Watt]
*BIOS 42 34.2
**Idle 39.6 31.2
***100% all 4 cores 54 46.8
Test computer components:
MB Gigabyte GA-EG31M-S2
CPU Q8400S (65W TDP) underclocked @ 2GHz and undervolt to 0.925 V
PCI-E DVI adapter Silicon Image
RAM 4GB (2x2GB OCZ2G8004GK)
SSD 32GB Samsung MCBQE32G5MPP-0VA (max 0.42W)
80mm 7V Fan
Multi card reader
All power measured at wall AC 120V the monitor is not included
* Power consumption when in BIOS
** Idle power in Ubuntu 9.04 (Linux)
*** 100% on all 4 cores using Blender 3D to render a scene using 8 threads
FCC report: Link (older model green PCB I also have that one for sale see my other items )
Spec: Link (older model green PCB I also have that one for sale see my other items )
High efficiency DC-DC Power Supply
Output over-current protection
DC soft start function, low inrush current
Short circuit protection
RoHS Compliant. (Lead free)
No minimum load required
Input: AC 100-240V, 50-60Hz
Output: DC 20V 11A
Power: 220W
Connecter size: 4-pin tip.
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
Post edited by doctorcilantro on
pics.For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center -
picsFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
