Ceiling Mount for tsi100
ScottyB
ScottyB Posts: 2
I'm in the process of putting new speakers in my dedicated media room. I have a CS10 center and a pair of tsi200 for my fronts. I'm going to wall mount a pair of tsi100 for my sides and would like to ceiling mount a second pair of tsi100 for the rears. The question I have is; are there any recommendations for ceiling mounting these speakers short of building a shelf that hangs down from the ceiling. I currently have a smaller pair of speakers ceiling mounted using a Vantage Point universal mount. I'm not sure these will work for the heavier speaker though. I'd like to find out if there are any recommendations for a mount that could be used for the tsi100 or if anyone has had any experience mounting them on the Vantage Point mount. Thanks in advance.
Post edited by ScottyB on
  • camp21178
    camp21178 Posts: 273
    edited June 2010
    I just wall mounted a pair of TSi 100's and the included brackets worked great. They're only 10 pounds, and if you use a lag bolt and an open end wrench, they could snug right up to the ceiling. You probably have a hole up there from your existing mount, so it won't cost you anything to try it. Good luck and welcome aboard! I have learned a lot from this forum in a very short time and I know that somebody out there probably has a better idea.
  • flyfisher
    flyfisher Posts: 220
    edited June 2010
    Look into the B-Tech77.They should work fine.
    Living Room Monitor 60's*CS2*FXi A6's*VSX 21txh*BD-P1590
    Spare Room RTi A7*CSi A6*FXi A4's*Epik Legend*BDP-05fd*DVL-919 Laserdisc/DVD player
