HELP! What amplifier to get???
  • cheddar
    cheddar Posts: 2,390
    edited June 2010
    I would say I use my system for 60% HT and 40 % music. I am running a 7.1 setup also. That is why I was looking at a 5 channel and a 2 channel.
    Surrounds may only see a tenth to a hundredth of the watts your front three speakers see. It's always convenient to have a 5+ channel amp to give the same amplification potential to all your speakers, but in my experience, the best bang for your buck is to put your money into your front three speakers first. Then the others as funds allow. The shock and awe for both HT and music come mainly from the fronts. And even running the surrounds off a receiver, I doubt you'll notice much of a difference as long as you've got enough power on the fronts.
    Just my opinion, but if your funds are tight, I'd use your money to buy a nice at least two-channel adcom, rotel, parasound, etc. to try out amps near the 200+ watt range cfrizz suggests. Then you can always buy a 5-channel later as funds allow. But at least you'll have quality amplification on the front mains first where it makes the most difference.
  • Pycroft
    Pycroft Posts: 1,961
    edited June 2010
    I agree that the fronts and center get the most benefit from amplification. At the very least, if you still wanted my 5 channel for the surrounds, back, etc. and have a 2 channel for the front two, that would be great. If you were doing it like that, and don't have the 2 channel yet, the 5 channel will allow the receiver to more effortlessly support the two speakers that aren't being used. I got your PM and will wait to here from you.
    James
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
  • rmknotts123
    rmknotts123 Posts: 144
    edited June 2010
    Rotel RMB-1075 vs Carver AV-505
    Both are 5 channel, however the Rotel produces 125 watts x 5 channels and the Carver produces 80 watts x 5 channels + power steering.
    Which would you take, the Rotel or the Carver?
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited June 2010
    Carver will be a challenge to get serviced/parts should you need it. That's another thing to consider. Between the two, I'd go Rotel.
  • rmknotts123
    edited June 2010
    Thank you for you input.
    F1nut Posts: 51,944
    edited June 2010
    For starters, I seriously doubt that you will notice a difference based on wpc between those two. There's a lot more to how an amp performs than wpc. Current and voltage matter more.
    Carver, Parasound, B&K, Adcom and Rotel.
    Is the record broken?
  • Sherardp
    Sherardp Posts: 8,038
    edited June 2010
    You have a modest budget but this Outlaw Amp is freaking in excellent condition and should last you with any upgrades you make in the future. The price is really good and Outlaw Amps perform very well, the customer service is awesome too. Jump on it.
    http://www.audiogon.com/cgi-bin/cls.pl?ampsmult&1281252558&/Outlaw-7500-200w-x5-8ohm---300
  • bld
    bld Posts: 25
    edited June 2010
    The Sunfire (Carver) as mentioned above will give you all the power you need with vrtually no heat.I bought the Sunfire 7401 with 400 wpc @ 8 and 800wpc @ 4 ohms.unbelievable dynamics and drive.Probably the last amp i buy.
    nad t175 processor
    Sunfire TGA 7401 amp
    LSi15 front
    LSi center
    LSI 9 surround
    dual sunfire hrs 12 subs
    LG bd 390 blueray
    Sonos
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited June 2010
    Looking for used more than new. I would like one that has passed the break in period. Max would be $1200 used and or new.
    With that kind of budget, I'd look seriously at the sunfire equipment. Lots of Sunfire 200X5 amps for sale on Audiogon right now.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • Ric5811
    Ric5811 Posts: 400
    edited June 2010
    Carver 705x, or Sunfire. I use a a Carver 505x for my A7's and I can shake all 2400 sq ft! And the amp doesn't even get hot...Also I would recommend the NAD 955, 100wpc, very underrated...at Audiogon for 799..new.
    Polk RTi A7's FrontPolk CSi A4 CenterPolk Tsi 100's SurroundOnkyo TX-RZ50:)Oppo BDP 83 (Collecting dust)MIT Terminator 3 Speaker CableMIT Terminator 2 IC's (Oppo 2 chan)Signal Cable HT TWOEpson PowerLite Home Cinema 1080Hisense 55 U8GBelkin PF 60 Power Center
