Polk 10" db's
tonykrz
Does anyone know the specs for a 1998 polk db 10? If so, which new polk sub is comparable. Mine blew and I don't want to have to build another custom enclosure.
Post edited by tonykrz on
Thanks for the info Kim.
... If you can dig up some DX10's they'll be close.
... the Momo 104 is a different breed of cat pretty much. if you want to go with a new sub, then I would say the 2104 would be the way to go. and personally, were i go to buying subs today, and I was looking for such a speaker, I'd be buying 2104's. I'm partial to "snappy" yet heart thumping stuff
check out sounddomain.com - they're carrying polk now! and cheap!Testing
Testing
Testing -
Thanks for the info Powered.
