Nine Inch Nails-Ghosts I-IV
cstmar01
So I've always been a Nine Inch Nails fan, however had mixed feelings about this work seeing it was all instrumental and not the normal NIN that a lot of people know. Well I ended up picking it up on Vinyl today and I'm pretty impressed. 4 double side LP's make for some nice 2 channel time.
I enjoy the differences between all the tracks. You have some nice mellow piano followed by distorted guitar and just makes for a nice, different type of flow that you really don't see or hear often. Trent does make a different recording out of this, and even though its not his normal thing, I still enjoy it and would recommend. I picked it up today for 30 bucks and for getting something that is different is a nice change up. Some will simply not like the instrumental aspect but I find it kind of nice to sit down and play and just listen.
I personally would recommend getting this if your out for something different.
Post edited by cstmar01 on
Industrial elevator music. I like it for background music though."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Adrian Belew. Need I say more?
Reznor: "The rules were as follows: 10 weeks, no clear agenda, no overthinking, everything driven by impulse. Whatever happens during that time gets released as ... something."-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's
