component cables 720 or 1080????
K-daugh
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere
Custom Jumpers
Post edited by K-daugh on
I am pretty sure component cable can only pass 1080i, but then your TV can convert it to 1080P. Hope that helps.
component can pass 1080P but Xbox 360 is the only device I know of that will allow that.
Most devices and AVRs will not pass 1080p over that cable. SOmething about it being analog and not reconizing video restricting content ability.Speakers: SDA-1C (most all the goodies)
so what the resolution be from a regular dvdBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
-Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers -
A normal old scholl DVD player is 480i, and a progressive dvd player is 480p. An upscaling dvd player can do 720, 1080i or 1080p.
