how do you get subwoofer ouput when just running stereo setting on receiver?
ksnisbet86
I like listening to music in regular 2 channel stereo but would like to have a bit more bass so i want my subwoofer to kick on but it wont, is there a certain setting i should have it on; on my receiver or a setting that should be turned on? Any suggestions would help thanks!
Post edited by ksnisbet86 on
Make sure your sub is set to on in the settings in your receiver.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
More details on which model receiver would help!TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
I think in the other thread the OP said he had a Pio SC-05?
Check your AVR modes for listening.
Some AVRs have a setting called "Pure Direct" or "Direct" which will pass only 2-channel audio to your front left and right outputs - the sub turns off.
There is a different mode sometimes called "Straight" or "Stereo" which will allow you to keep your sub on.
The difference is for Pure Direct or Direct, if you have an analog source, then the signal stays analog all the way thru the AVR and is not reconverted to digital and then back again inside the AVR using the AVR DACs.
Some may prefer the signal to stay analog all the way thru to their speakers.
But the trade off is - no sub output on the back of the AVR.
If you don't mind the AVR doing the final D/A conversion then give up Pure Direct and live with Straight/Stereo.
alright that makes sense ill give that a try, thank-you!
