VIFA Tweeters new RTi series
adclark
adclark Posts: 29
edited November 2003 in Speakers
I wonder if you could upgrade old RTi with new VIFA tweeters. They are not very expensive
Post edited by adclark on
  • dorokusai
    dorokusai Posts: 25,576
    I am sure that it COULD be done....but you are talking cabinet modification, and crossover work, minimum. I wouldn't recommend it, it would be easier to just buy the new ones. It would be cool, if they were drop in replacements, but they aren't.
  • Emlyn
    Emlyn Posts: 4,702
    I'd consider them to be newer, but not necessarily an upgrade. Upgrade suggests they're better. They definately sound different but I prefer the previous iteration of the RTi line much more for music. The brighter sound may be a little better for movies though.
