Near Field Amplification
MillerLiteScott
I currently am using this little system for my computer rig.
Sony HD radio-- Laptop--Modded Maverick D1 Tubed Pre amp/DAC--Accurian $15 amp modded as a straight amp--Modded Insignia NS B2111 speakers.
What budget amp do you think would suit me best for my nearfield listening experience. I am considering a Adcom 535 II, S-5 16 watt stereo kit, www.ClassDaudio.com CDA 224 or SDS 224 kits or any other suggestions.
I am leaning toward a Adcom 535 II which usually go for around $100 and maybe get a SqueezeBox Touch/ Duet or Apple TV and still stay @ my $400 budget.
All the other amps I am looking at are $300-$400 for the amp, case and misc. parts and pieces.
Or should I just stick with my little Accurian amp?
What are you near field amplification experiences?
Thanks,
Scott
Thanks,
Scott
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Post edited by MillerLiteScott on
I'm using an LM3875 Gainclone to drive a pair of Zaph ZA5.2 monitors for my PC rig.It's clean and detailed perhaps maybe a bit on the analytical side but is dead quiet which for me is important when sitting in the nearfield.
Gainclone and upgraded crossovers."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
What gainclone do you recommend and what am I looking at $ wise?
I am a bit cheap these days.
Thanks,
ScottI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
That is our friend Doccilantro.I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
A little single-ended EL84 stereo amp could be awfully nice in that application. Just sayin'...
I think you can do much better than the Accurian. I got by with one of those for a couple years. Sounded fine, but then I upgraded to an NAD integrated and it was night and day improvement, especially in the bass dept. I ended up moving further up the NAD scale and am now quite happy with a 7175PE receiver (although I'm sure I'd be happy with one of the lower powered models as well, it just worked out that I got the more powerful one cheaper).
Since you already have a pre, I'd say you would be good with one of the lower powered Adcom, Rotel, NAD, Proton, or similar amps. The Gainclone thing would be nice too. -
mhardy6647 wrote: »A little single-ended EL84 stereo amp could be awfully nice in that application. Just sayin'...
or even a PP EL84 amp... might be a nice amp in that application....
just sayinYamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie -
but of course :-)
I was just thinkin' nearfield and a couple of Fostex extended range drivers (e.g., one of the Tekton models) would be dandy with 2 watts (SE EL84 pseudo-triode) or 4 watts (SE EL84 pentode). -
nope....
you want this little maggotbox SE 6BQ5 amp....
http://cgi.ebay.com/Magnavox-single-ended-6BQ5-Stereo-Tube-Amplifier-/110534888233?cmd=ViewItem&pt=Vintage_Electronics_R2&hash=item19bc648b29
and a pair of Dynaco A25s or A10s even....
I've got my mac mini running windows xp, with a USB Creative Labs MP3+ playing iTunes and WinAmp (really kicks the lama's ****) into my Maggotbox 9302-00 PP 6BQ5 PP 13w per channel -- Pushing my Dynaco A25s (SEAS Dome Tweets).
Man it sounds belly belly good.
-- wayne --Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie -
heh, I hear ye; I have an EL84pp Maggotbox stereo amp in the basement hooked to AR-3s for nearfield... even more nuts than A-25s... but it works for me.
The old Magnavox amps, SE and PP, are surprisingly good sounding for what they are (and aren't) -
Thanks Wayne3burke I now have that on my watch list. That is something that would be fun to have, Do you know what they usually go for and how much power they have?
I am guessing 10-15 watts?
I think the SE (single ended - one output tube per channel) is about 5-8 watts. where the push pull (two output tubes per channel) is about 10 -15.
I've seen unmodded PP models go for anywhere from $125 - $175. If they've been modded with an on/off switch, fuse, standard speaker outs, and replacement caps -- upwards from $250 to $400 (if someone has built a wood plinth for it).
I pulled mine from a thrift store find that cost me $30.
good luck
wayneYamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie -
SE EL84 (6BQ5) pentode mode is about 4 watts.
PP about 12-14 watts in pentode mode (you can get a little more out of the 7189 tube, which is beefier than the EL84 and can take higher plate voltage). The "modern" Soviet-made 7189 equivalents (6p14p-ev, if memory serves) are nice tubes and not expensive.
There is a Magnavox group at Yahoo, and plenty of info on the amps at forums like audiokarma and audioasylum.
