Recommendation for Power Amp to drive SRT's
dpowell
dpowell Posts: 3,081
edited May 2010 in Electronics
I'm going to be upgrading from an Adcom GFA-7500 to something else to power my SRT's at some point and would like opinions on what to get. I'd like to stay under $2,000 if possible so here's what I'm considering:
Parasound Halo A51 - likely a +$2,000 amp used but has amazing reviews
B&K Reference 200.7 - not as powerful as the A51 but 2 more channels and still a quality amp. Can get one for around $1,500
Earthquake Cinenova Grande - Don't know much about these but it has the most power of them all and there's one on the 'gon for $1,395.
Anything else I should consider?
My main goals:
Feed the beasts all the power they want
Tame/smooth the highs
Each SRT satellite will get two channels from the amp for a total of 4 channels dedicated to the mains.
Post edited by dpowell on
  • Dawgfish
    Dawgfish Posts: 2,554
    edited May 2010
    You really can't go wrong with the B&K or Parasound. I prefer the B&K by a hair, but YMMV.
  • unc2701
    unc2701 Posts: 3,587
    edited May 2010
    The reference 7270 is pretty much identical to the 200.7 and a lot cheaper. IIRC, there's minor tweaks, but they sound exactly the same to me. Hell, call their service department- they're really helpful and can probably tell you if there's any difference.
    Backburner:Krell KAV-300i
  • ESavinon
    ESavinon Posts: 3,067
    edited May 2010
    I run my secondary SRT system with the A51 with good results.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • dpowell
    edited May 2010
    ESavinon wrote: »
    Ed,
    I remember you saying you had a Halo A51 for yours. What do you run on your primary SRT rig? BTW, nice signature. I bet you've spent quite some time accumulating that many SRT components! :D
  • Bernal
    Bernal Posts: 991
    edited May 2010
    Amplifier
    SUNFIRE
    Theater Grand Amplifier - TGA-7201
    Power Output (8 ohm, 1kHz)
    Front 200W + 200W
    Center 200W
    Surround 200W
    Surround Back 200W
    Output at Clipping 400W / Ch at 4 ohms
    Maximum Output Voltage 40Vrms
    Maximum Output Current 80A p-p / Ch
    THD < 0.5%
    Damping Factor 150
    Hum and Noise -115dB, A-weighted
    Sensitivity Balanced(for rated output) 0.65Vrms
    Sensitivity Unbalanced(for rated output) 1.3Vrms
    Connections
    Output Impedance (Front) Voltage Source Approx. zero ohms
    Output Impedance (Front) Current Source Approx. one ohm
    XLR Input Impedance 10kohms
    RCA Input Impedance 24kohms
    Trigger Inputs
    Voltage Range 5 - 18VDC
    Impedance Approx. 600ohms
    Turn-On Current 20mA @ 12V
    General
    Power Consumption (120VAC, 50-60Hz) 280W (1/8th power)
    Dimensions (W x H x D) 17" x 5.9" x 16.7"
    Net Weight 43 lbs
    01) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
    02) SUNFIRE Grand Signature - Bob Carver's
    03) OPPO BDP-83SE Blu-ray Disc Player w/SACD & DVD-Audio
    04) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
    05) DENON DVD-2500BTCI: Blu-ray Disc™ DVD/CD Digital Player/Transport
    06) HITACHI P55T501. 55" HD1080 Plasma HDTV
    07) POLKAUDIO LSiC (Center speaker)
    08) POLKAUDIO LSi15 LEFT (Front speaker)
    09) POLKAUDIO LSi15 RIGHT (Front speaker)
    10) POLKAUDIO LSiC Vertically (Surround speaker)
    11) POLKAUDIO LSiC Vertically (Surround speaker)
    12) POLKAUDIO LSif/x LEFT (Surround back speakers)
    13) POLKAUDIO LSif/x RIGHT (Surround back speakers)
    14) VELODYNE OPTIMUN SERIES 12"(High Output Digital EQ SubWoofer 2400W/1200WRMS)
    http://www.polkaudio.com/forums/showcase/view.php?userid=98096 (Not updated)
  • dpowell
    edited May 2010
    unc2701 wrote: »
    Interesting. I'll look into that. My understanding is that the older B&K stuff is a bit better quality.
  • thuffman03
    thuffman03 Posts: 1,325
    edited May 2010
    Sunfire is the way I would go.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • ESavinon
    edited May 2010
    My second system uses 3 NAD 208 thx amplifiers.
  • dpowell
    edited May 2010
    thuffman03 wrote: »
    Thanks. Do you have any specific reasons you prefer the Sunfire over the others?
  • ESavinon
    edited May 2010
  • ESavinon
    edited May 2010
    dpowell wrote: »
    Ed,
    It took me 3 years and a few road trips to finish my SRT collection ;).
  • dpowell
    edited May 2010
    Nice list Ed and thanks for sharing. I love my Anthem products and that looks like a sweet amp. I may have to open my horizons a bit more before pulling the trigger on something. My main concern is taming the dang tweeter on the SRT's. It's too bright and harsh with the Adcom. I don't want to end up with something (an expensive something) that doesn't manage those tweets well.
  • dpowell
    edited May 2010
    ESavinon wrote: »
    Have you managed to find a pair of the elusive SDA rears?
  • dpowell
    edited May 2010
    Thanks for the help. I found that the B&K I was looking at is too deep to fit in my cabinet (by about 2 inches). I just found a steal on 3 Parasound HCA-1200 II 2 channel amps locally. They are 205wpc @ 8ohms which is a big step up from what I was using previously. I'm going to use them for awhile and see how I like the Parasound sound.
    nooshinjohn Posts: 25,963
    edited May 2010
    Sunfire Cinema Grand Signature 425~7 or it's more current relative the 7400 would be the way to go if they were my speakers, but I went with the Parasound for the voting... The 200wpc Sunfires are not as dynamic as the 400wpc versions.
  • dpowell
    edited May 2010
    Thanks. That's a nice vote of confidence since I ended up with some Parasounds (although not the one I listed). :)
  • ESavinon
    edited May 2010
    dpowell wrote: »
    Yes I did! The last setup found had the SRT rears. I found those in IOWA.
  • Dawgfish
    edited May 2010
    I think you'll be very happy with the Parasounds. They make great products. You really couldn't have gone wrong with the B&K, Parasound, or the Anthem (which another poster mentioned). I have owned all three and they are very, very close in overall performace. So close were it really would come down to which one you could find the best deal on as far as which one to recommend buying.
