Tweaking my RT55's and CS400
Ron-P
Ron-P Posts: 8,520
edited May 2010 in DIY, Mods & Tweaks
These are my front 3 main speakers in my HT room. I've had them a very long time. I think I am ready to upgrade there components, thing is, I have no idea what to do or how to do it. Maybe crossover tweaks, new drivers / tweeters. I don't know but I wouldn't mind doing something.
Any ideas, tips or suggestions?
If...
Ron loves a film = don't even rent.
Post edited by Ron-P on
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2010
    Patrick listed some mods for these a while back and said they were a very good improvement...
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Ron-P
    Ron-P Posts: 8,520
    edited May 2010
    Any idea where I could find that info?
    If...
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2010
    Have you thought about trying some different speakers?
  • vmaxer
    vmaxer Posts: 5,121
    edited May 2010
    My bad, it wasn't Patrick...sorry, see this thread, post 60 is what I was "trying" to remember:o
    http://www.polkaudio.com/forums/showthread.php?t=79767
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • dubradio
    dubradio Posts: 181
    edited May 2010
    That would be me :) ,
    The simplest and most effective route is replacing the capacitors on the RT55 and CS400 crossovers. Very simple to do with basic soldering skills.
    Simply replace the Electrolytic capacitors with Polypropelene capacitors, equal values, however i recommend uping from the "stock" 50volt caps to 250 volt caps.
  • Face
    Face Posts: 14,340
    edited May 2010
    If space allows, replace midrange and woofer caps with Dayton or Claritycap. As for the tweeter circuit, it may have a film and electrolytic cap in parallel, combine both values and replace with a single, high quality film cap such as a Sonic Cap or Claritycap PX/SA.
  • dubradio
    dubradio Posts: 181
    edited May 2010
    ^ Great input.
    OP dont stress over spending alot of money on caps though, I tested Solen, Dayton, Claritycap. Between the 3 there was negligable differances on the RT55 and no discerable differance on the CS400.
  • Ron-P
    Ron-P Posts: 8,520
    edited May 2010
    So by doing this what exactly will it do, or change, with my speakers?
    If...
  • Face
    Face Posts: 14,340
    edited May 2010
    Increase transparency, coherency, dynamics, etc...
  • dubradio
    dubradio Posts: 181
    edited May 2010
    ^ this. By replacing the electrolytic caps with Polypropelene caps you reduce the amount of signal loss across the electrical network, which in turn increases transparency, dynamics, coherency, etc...
