How important is the timbre on the surround sound?
polkfarmboy
Just wondering if any polkys have different surrounds from the 3 fronts
I am pulling the plug soon for a martin logan centre channel to pair up with my source but was wondering if I can use my existing rti8 and 6's for surround sound duty
Does the surrounds have an entirely different sound encoded for movies or do you think it will be horrible and not even worth unpacking the polks
Post edited by polkfarmboy on
i dunno.. worth trying out though and finding out for sure.
surrounds don't usually carry any dialog... so i would think it would not be a big deal if they were different. just as long as you run the auto calibration in your system. you should be ok.PolkFest 2012, who's going>?
I would keep the front end the same, the rears aren't as important."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thats the plan ... have a front soundstage all electrostat
I use all the same. The result is excellent
______________________________________________________
01) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
02) SUNFIRE Grand Signature - Bob Carver's
03) OPPO BDP-83SE Blu-ray Disc Player w/SACD & DVD-Audio
04) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
05) DENON DVD-2500BTCI: Blu-ray Disc DVD/CD Digital Player/Transport
06) HITACHI P55T501. 55" HD1080 Plasma HDTV
07) POLKAUDIO LSiC (Center speaker)
08) POLKAUDIO LSi15 LEFT (Front speaker)
09) POLKAUDIO LSi15 RIGHT (Front speaker)
10) POLKAUDIO LSiC Vertically (Surround speaker)
11) POLKAUDIO LSiC Vertically (Surround speaker)
12) POLKAUDIO LSif/x LEFT (Surround back speakers)
13) POLKAUDIO LSif/x RIGHT (Surround back speakers)
14) VELODYNE OPTIMUN SERIES 12"(High Output Digital EQ SubWoofer 2400W/1200WRMS)
http://www.polkaudio.com/forums/showcase/view.php?userid=98096 (Not updated) -
Thanks for digging deep into the fathomless pit of the accumulated wealth of knowledge guys
I've had experience with this recently. I started out with R50's in the front, CSM center, and four R150's for the surrounds. The tweeters were different in the R150's compared to the front three. It sounded fine, but I found a deal on some T15's which have the matching tweeter to the R50's and CSM so I decided to try it. I find the surround to be much more seamless with the matching speakers. So, I wouldn't say it is absolutely necessary, but I still recommend it.
polkfarmboy wrote: »Thanks for digging deep into the fathomless pit of the accumulated wealth of knowledge guys
hahaha, now thats a funny statement.Onkyo TX-SR805
Polk LSi15 , LSiC, LSiFX
Parasound Halo A52
Panasonic 42'' Plasma
Oppo BDP-83
Sonos
Panamax 4300
Audioquest cables -
Ideally, you want all the speakers to be matched, but matching the surrounds to the fronts is less crucial than having a timbre matched front soundstage. Give it a try and see how it sounds. My guess is that it will sound great.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
its not entirely necessary, but having matching timbre on the surrounds makes them VERY hard to seperate from the rest of the speakers, which is a good thing because you tend to forget you listening to speakers and fall into the movie. for music i would say its a must, everytime ive set up a PLIIx music system ive always preferred to have matching surrounds because you can tell you have seperate speakers for surrounds rather then just having an expanded stereo image.
Curt and Face are right above but let Polk lay it out straight for you. In their newest entry line....NOT ONLY are the TSI drivers all matched but so are all the crossover points. EVERY TSI crosses over at 2500 kHz? Now gentlemen....start your engines. The question is WHY? The answer I do not think is hard to 'imagine'. Why would Polk do that?
Is that 'deep' enough for you....?
I have a set of TSi 500's that I run as surrounds in my otherwise strictly Monitor setup. It sounds great that way. I know when I had the 500's up front, they did not blend well with my CS2 center. Keep the front 3 timbre matched, that is the most important part. The surrounds aren's as important, as stated above.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
