Wii and Netflix
apc
apc Posts: 779
edited May 2010 in Music & Movies
My daughter has a Wii and I hear Netflix can be streamed using the device. We don't have an account yet, but is it worth a try given the limited IQ of a Wii vs a 360 or PS console?
Husband, Father, Son, Brother, Friend.
Post edited by apc on
  • tcrossma
    tcrossma Posts: 1,301
    edited May 2010
    I guess it depends on what you are wanting to use it for. I've had no trouble with the Wii streaming, and it looks quite respectable on my 34" CRT HDTV. Couldn't really tell you about sound as I just have it running through the TV.
    The only semi-annoying thing is that the NetFlix disc has to be in the drive when streaming.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • apc
    apc Posts: 779
    edited May 2010
    OK. We are used to DVD (not Blu Ray) quality. I was just wondering how the images may compare on a 50" plasma.
  • apc
    apc Posts: 779
    edited May 2010
    Wow, not sure about that. Thanks for the heads-up. I have a "N" router but doubt I pay for a premium broadband service.
  • bobman1235
    bobman1235 Posts: 10,822
    edited May 2010
    You most certainly do not need a "very good N router" to stream Netflix.
    802.11g streams at 54Mbps. It's quite a bit faster than your 3Mbps internet service.
    I got the disk from Netflix a few weeks ago, and the quality is OK, definitely not DVD quality but it's OK.
  • apc
    apc Posts: 779
    edited May 2010
    Thanks. That's what I was fishing for - a comparison to DVD picture quality. Might be worth trying on the trial basis. I'll contact Netflix about acquiring a disk.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2010
    +1 on what Bob said, mostly:
    Mine works fine with a G router, 54 mbps is much faster than your internet connection is anyway. The only advantage I think you may have with a N router is distance, as I wanna say the range is longer on them, though to be fair I'm not certain on that, worth looking up though.
  • tcrossma
    edited May 2010
    Doesn't the Wii just have a built-in wireless B/G adapter anyway?
    As far as quality, probably not DVD quality but pretty darn close for me, at least on my 34" TV. Obviously the larger you go the more you'll notice, so it might not look as good on a 50".
    Plus, I believe NetFlix adjusts its quality based on your connection speed, and also on their current bandwidth usage. So if you're asking to stream a movie at prime-time, you might get slightly less quality.
  • yepimonfire
    yepimonfire Posts: 256
    edited May 2010
    apc wrote: »
    i use this all the time and it looks just as good as a dvd, no 5.1 though, if you have Dolby Pro Logic II, its no problem, just set it to movie mode, it does an outstanding job of re-creating a surround field from 2ch.
    and there is no macroblocking or compression artifacts visible.
  • Mike Kozak
    Mike Kozak Posts: 931
    edited May 2010
    I told my Dad about this a couple weeks ago, he got the CD and he loves it! He has a Poloroid 46" TV with a pretty darn good picture. Never knew Poloroid even made TVs.
