Two amps to one set of RtiA5's
specd_out
I know this sounds like a really stupid question, but let me explain my situation.
My setup
Yamaha VX463
Rtia5
Csi3
T-15
DSW Pro 600
I love my 463 It works great for my HT but I know I can do much better for 2ch music listening. The problem is that the 463 does not have preouts, and I dont think its wise for me to spend $400+ for a new AVR with preouts and then spend another 300+ for a 2ch amp.
Here is what I wanna do. My dad has a carver amp that he isnt currently using. i would like to run my cd player directly to the carver and then power my rtia's with the carver, But I still want my Rtia's to be used in my HT. So in simple terms my question is, Can I have both amps wired to my speakers and not have any issues. As long as they arent both on at the same time I cant seem to think of any downsides to doing this. I am still a novice in HQ audio so this is why I want to ask your guys opinions on this.
My setup
Yamaha VX463
Rtia5
Csi3
T-15
DSW Pro 600
HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
ISF Level 2 Certified Calibrator
Post edited by specd_out on
I would not recommend this...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Yeah, neither would I. Maybe banana plugs then swap the cables depending on what you want to listen to.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
I have banana plugs already. Just out of curiosity why isnt this a good idea.HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
ISF Level 2 Certified Calibrator -
Doing so feeds voltage / current back to amp which is off, and in the wrong direction since it designed to feed not to be feed.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
disneyjoe7 wrote: »Doing so feeds voltage / current back to amp which is off, and in the wrong direction since it designed to feed not to be feed.
makes sense to me. ThanksHT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
disneyjoe7 wrote: »Doing so feeds voltage / current back to amp which is off, and in the wrong direction since it designed to feed not to be fed.
fixed it to be more clear:) -
Thanks I'm always clear.... Drugs? Lack of or too many before?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
This AB selector switch (http://www.volutone.com/RUSS-AB22-TBL-TOP-SPEAKER-P692.aspx) would allow you to use your 463 and Dad's Carver amp safely on the same pair of speaker.I know this sounds like a really stupid question, but let me explain my situation.
My setup
Yamaha VX463
Rtia5
Csi3
T-15
DSW Pro 600
Cheers!
TKDARE TO SOAR:
^ Thanks Thats definitely a optionHT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
