Build me a cheap 2CH system
polkfarmboy
polkfarmboy Posts: 5,703
edited May 2010 in Electronics
This place seems to shine on the wealth of advice for used 2 channel gear so I was hoping you guys could share some of it with me
What pre and amp combo iunder $1000 could I get to use with either my RTI8 or ML source se ?
What would be a decent cdp around $400 with a good analog signal path
I have my eye on what cables I want from previous posts
'''''' just made it in time to edit"""""""" Even just listing one used component can give me a price point of what to look at for future reference
Thanks polkies
Post edited by polkfarmboy on
  • Face
    Face Posts: 14,340
    edited May 2010
    New or used? Used, check out the Cambridge 540/550 series.
  • polkfarmboy
    edited May 2010
  • ben62670
    ben62670 Posts: 15,969
    edited May 2010
    Look at HK direct on ebay for a 2 channel receiver they really have plenty of power, and pre outs if you want to add an amp later. If you shop smart you can get a good deal.
    Ben
    Ben
  • polkfarmboy
    edited May 2010
    I have heard you guys say you need separate components for 2ch
  • ben62670
    edited May 2010
    It's not needed. HK is one of the few companies left that still make a solid 2 channel receiver. Most of them are real good high currant designs.
    Ben
