AR MS321 Masters Series 25ft 10 AWG Speaker Wire
Conradicles
Conradicles Posts: 6,345
edited May 2010 in For Sale (FS) Classifieds
I bought a pair of these some time ago when PartsExpress was selling them really cheap. I gave one run to a new polkie, and here for sale is the other 25 FT cable.
Again, this is for (1) 25FT speaker wire with bananas on each end. You can custom cut to length if you want to make a pair. This cable is new and has never been used. Looks exactly like the ones in the pictures.
Here are some details:
"The precision-machined Acoustic Research MS321 Master Series 25 ft Speaker Wire Cable pair has 24k gold-plated AdaptaTips banana ends which ensure the tightest connection possible. Solder-free termination for maximum signal transfer and accuracy. Color-coded AdaptaTip design permits easy-to-connect, screw-on conversion from pre-installed banana plugs to optical spade connectors. Corrosion-free 24k gold-plated surfaces maximize audio signal transfer. 10 ga. alternating fine-stranded roped layers of oxygen-free copper and precious silver-coated oxygen-free copper for accurate reproduction of all frequencies. Contains 2X 25 ft. speaker cables.
10 AWG Separate Alternating Rope Layer Construction
Oxygen-free copper and Precious Silver-Coated OFC
Solder free termination
Uses the Master Series AdaptaTip for quick speaker termination changes"
$27 shipped and PayPal preferred.
Thanks!
Eric.
Post edited by Conradicles on
