Difference Between Receiver Listening Modes
Cpyder
Cpyder Posts: 514
edited May 2010 in 2 Channel Audio
So I'm listening to music today and I'm thinking to myself, "I'm just not getting any effect out of music today. It's not making me happy. It's not pleasing like it usually is." I just assume I'm not in a listening mood. (Which rarely if ever happens)
Then I realize that my Marantz receiver is in "Stereo" mode. I switch it to "Source Direct" and a smile jumps onto my face. The sound stage opens up and the music is very realistic and convincing again.
So my questions is: What is the difference between these two modes. What does "Source Direct" do that makes is sound SO SO much better. (Or the opposite question: What does "Stereo" do that kills the music?) I know "Source Direct" bypasses any equalization but even in "Stereo" the equalizer is flat. So what's the cause of the difference in sound?
Post edited by Cpyder on
  • Jetmaker737
    Jetmaker737 Posts: 1,113
    edited May 2010
    My Onkyo behaves the same way. In stereo mode the signal goes through the DSP which destroys the soundstage. Direct mode skips the DSP.
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited May 2010
    Cpyder wrote: »
    Source Direct *can* sound better.
    If you are listening to an analog connected source, then the signal stays analog all the way thru your AVR and like Jetmaker notes - there is no DSP and no additional Analog to Digital conversions and the final Digital to Analog conversion before leaving your avr to your speakers.
    Depending on the AVR, 'no DSP' means no room equalization/PEQ profiles that you get by default when you run auto calibration features like Audessey or YPAO - instead you get no equalization - just straight signal.
    And if your source is say a CD player and it is connected via analog, then you are listening to the CD player's DACs - not your AVRs.
    If your source is digitally connected, again, say your CD player, or blu ray, then you are listening to the AVR's DACs, but again - no DSP effects which are bypassed.
    One drawback to Source Direct, depending on the AVR, is that you do not get any sub output as Source Direct is a 2-channel mode only, not 2.1. But it does depend on the AVR.
  • Cpyder
    Cpyder Posts: 514
    edited May 2010
    Erik Tracy wrote: »
    Well I run digital optical from my computer. So do you think in "stereo" mode, it's still doing some sort of processing even though the equalizer is flat/off.
    And I'm not running a sub, but I didn't know that. Thanks! That could have caused some headaches in the future if I get a sub or put together a new setup.
  • samnor
    samnor Posts: 155
    edited May 2010
    Just my 2cents: I have an el cheapo onkyo avr and actually prefer it in stereo for the reason posted by E. Tracy since I prefer the sub output... gives much more headroom to my main LR towers speakers (even though the towers go down to 30hz its still much better to have the sub handle the lows while the towers handle everything above the 80hz crossover).
    Fronts: Wharfedale diamond 9.6
    Sub: Wharfedale sw250
    Rears: Wharfedale diamond 9.1
    Center: Paradigm cc-350
    Pre-amp: Oppo dv981hd
    Amp for fronts: Parasound hca-1500a
    Amp for rears: Adcom gfa-5400
    Amp for center: Marantz MA500 monoblock
    Polk multimedia speakers for PC setup
  • Erik Tracy
    edited May 2010
    Cpyder wrote: »
    Not sure about your exact model of AVR. I've seen block diagrams of my AVR and in Source Direct, a digital input flows thru the AVR straight to the DACs and out to my speakers - bypassing any Digital Signal Processing (room EQ, special effects, multichannel synthesis, etc).
    This may explain why you prefer the sound.
  • vc69
    vc69 Posts: 2,500
    edited May 2010
    I will jump in here and say this: *most* AVR's and pre/pro's digitize analog inputs. This has been discussed at length on other sites and the common consensus is that the only inputs on the average AVR/PRE/PRO that are not converted within the unit are the multi-ch inputs which will actually pass through without any A/D conversion.
    In the OP's case, the fact that the digital signal is by-passing the DSP is most likely the reason for the better sound. I know it's true with my Onkyo that "direct mode" is the best sounding for all music sources.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • Erik Tracy
    edited May 2010
    vc69 wrote: »
    One should check their manual to be sure.
    I did - analog stays analog at the 2-channel inputs when the AVR (yamaha v1800) is put into "Pure Direct".
    vc69's warning is a valid one - especially for those that are looking to keep their TT and CDP with the 'killer DACs' as analog thru the signal flow.
  • Cpyder
    Cpyder Posts: 514
    edited May 2010
    Erik Tracy wrote: »
    It's the latest version of the SR5003 by Marantz. I think you're right. Stereo mode must not bypass the DSP and I would think bypassing un-needed circuitry I'm not using would help with sound quality. If I was applying effects and using the DSP circuitry it may be a different story, but I'm not. I really don't even think it's subjective in this case - source direct sounds SO much better.
    So in source direct, I'm only using the receiver's DAC and amp?
  • Face
    Face Posts: 14,340
    edited May 2010
    Receiver and music don't mix.
  • Erik Tracy
    edited May 2010
    Face wrote: »
    Be nice... :)
    We all start somewhere and make the best of what we have.
  • Cpyder
    Cpyder Posts: 514
    edited May 2010
    Face wrote: »
    I don't agree with that. You should hear my setup in source direct mode. Pretty stunning in my opinion.
  • polkatese
    polkatese Posts: 6,767
    edited May 2010
    Just FYI, I have a Marantz Pre/Pro AV8003. Cpyder observation is spot on. Kevin (vc69) is also spot on. Since I use multi-channels 7.1 input for all my audio, it's definitely better than any other modes that it has. Source direct in most cases produces almost identical SQ, with the exception of lower register. The low-end is more pronounced using multi-channels input mode, thus let me to believe that additional processing is being applied somewhere somehow when source direct is engaged. Having said that, source direct is still better than the other modes other than multi-channels direct mode.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited May 2010
    Cpyder wrote: »
    Face man gave the answer, the Hardcore here tell it like it is, if someone gets their feelings hurt, well better sooner than later, I will pass on hearing your reciever but thanks for asking, sorry, but I and others here have heard and used an awful lot of gear, I never heard a receiver that was anything more than ordinary, even my B&K 317 which is just passable at audio, if you dont know why, then you dont, enjoy your rig.
    RT1
  • Knucklehead
    Knucklehead Posts: 3,602
    edited May 2010
    RT1
    I couldnt agree more....my simple 2 channel setup sounds MUCH better than my AVR for music.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • Cpyder
    Cpyder Posts: 514
    edited May 2010
    RT1
    I realize that separates are the better choice, but I also use my receiver for home theater use, and so it needs to be able to decode TrueHD and DTS-HD along with Blu-ray video. And at the time of purchase I was in no position to go the separates route. But anyway, I can guarantee you that if you heard my setup you would not say, "Hmmm... something is missing, you must be using a receiver and not separates." Not saying it's perfect, but there's no obvious defects from having gone the receiver route.
    Trust me, if the funds were available, the first thing I'd grab would be a nice standalone DAC and amp.
  • vc69
    vc69 Posts: 2,500
    edited May 2010
    Cpyder wrote: »
    That is correct
    Cpyder wrote: »
    Receivers are good at that stuff.
    Cpyder wrote: »
    I understand.
    Cpyder wrote: »
    That's where you are mistaken.
    I'm thinking you have never heard a really nice 2ch rig. There is absolutely no comparison.
    Cpyder wrote: »
    That is just the tip of the iceburg.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • reeltrouble1
    edited May 2010
    its fine, enjoy the paths where the hobby may take you, as said, we all started somewhere and we should enjoy each rig along the way, trust in your ears, they will tell you when to stop.
    RT1
  • vc69
    vc69 Posts: 2,500
    edited May 2010
    RT1
    RT1,
    It's not my ears that keep telling me to stop. :o
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Cpyder
    Cpyder Posts: 514
    edited May 2010
    vc69 wrote: »
    You may be right. I mean I've heard nice gear but maybe not really nice gear. I'd really like to demo some nice gear here in Iowa, but so far I've not been impressed by many higher-end audio shops. A lot the ones I've visited don't even have adequately sound treated rooms. When I added sound treatment to my listening room, it's like I had purchased all new gear. Know of anywhere near the Des Moines area by any chance?
  • reeltrouble1
    edited May 2010
    vc69 wrote: »
    RT1,
    RT1ism.........until your ears are full your wallet is empty. Remember the purchasing of necessaties is a self-fullfilling limit.
  • Jetmaker737
    edited May 2010
    Sir, I think you are a genius... or insane. I haven't decided which! :cool:
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited May 2010
    Cpyder wrote: »
    You sound like someone who's never gotten their ears on a decent 2 channel rig before. There is a BIG difference between a receiver and 2 channel separates. I'm sure your system does sound fantastic, and much better than the average persons audio system.
    Will it stand up against even really low end 2 channel gear though? I doubt it.
    I'm in Dixon, IL...not too terribly far from you. You're welcome to come check out my very budget 2 channel rig anytime. It sounds absolutely incredible, especially given the fact that I've only invested around $1000 in it.
    Although right now wouldn't be the best time really...I'm having issues with my SDA's and need to do some XO upgrades.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Face
    Face Posts: 14,340
    edited May 2010
    Let me elaborate.
    I've tried various receivers and pre/processors, from entry level HK to McIntosh. No matter what receiver or pre pro you're using, it's holding you back compared to what an external DAC, dedicated preamp and amp can do, even at much less $$$.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited May 2010
    Cpyder wrote: »
    It depends on your needs, 2 channels is for music and basically useless for HT just like HT AVRs are useless for music. Thus the reason for asking yourself this question at the start of your system building; what is the largest % of use for your rig? If mainly HT, going into separate is a waste of money and useless as you are missing MOST of the special effects of movies that an AVR will accurately generate. If your rig is mainly used for music and you can afford seperate, you better stay away from receivers or AVRs as they will not provide for the best music reproduction.
    However, most people want to rig both their audio and video experience. Some (very few) may be able to afford to have dedicated rigs for their audio and video (good for them). For the average people with average income, the reality is they have to use wisdom and common sense to built combo rigs which will accomodate for both audio and video experience thus the reason for pure direct on most receivers and AVRs. Life is give and take and you have to make the choices according to your own needs. You have to set your priorities; purist audio and-or video or settle for a balance that will live you in the middle lacking slightly on both end.
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • Cpyder
    Cpyder Posts: 514
    edited May 2010
    It'd be cool to demo your gear but I don't think I'll have any time in the near future to go on any road trips. But now I want to go grab a DAC and amp and swap them in place of my receiver and see just how much of a difference we're looking at.
  • reeltrouble1
    edited May 2010
    well, the rather common concenus is that RT1 is an insane genius lost somewhere in an Auditory Rabbit Hole.....go ask Alice how it happened.
  • Bernal
    Bernal Posts: 991
    edited May 2010
    Hello,
    I have a "Denon 4308Ci" - How to apply these concepts.
  • Jer.War
    Jer.War Posts: 180
    edited May 2010
    Not to stir the pot but...
    I started with a AVR and LSI all around. It sounded ok, but there wasnt much impact even on 2ch mode, and I knew from reading that the LSI15s like high current amps (which an AVR is not). I have recently added a B&K ST1400 II into the setup (using the pre-outs on my RXV1700) and result was better than I had anticipated. Sure it plays louder, but even at low volumes the music has more "weight" (The subtle details of the track are easier to distinguish). Also, the B&K is much smoother than the Yahama, the highs sounds smoother and clearer (I always felt my Yamaha was a bit bright).
    Now all that being said.... Was I happy when I first hooked up my system? Of course, I was 20 with a small budget that already swelled (I intended to buy a starter reciever and a used Polk surround setup on e-bay.....) and a pile of student loans to pay. However, I knew there was more to get out of my speakers. Now I had the money to buy a quality used power amp to take the strain of powering the LSI15s. I use the Yamaha for the pre (in straight or pure direct) and a high end denon CD player(connected analogue via RCAs).
    Now my system sounds much better what the average person listens to, and it puts a smile on my face (I am fairly critical, but until I strike it rich my being a student forces a healthy amount of pragmatism into my judgements).
    Does my setup sound as nice as my bosses 2ch rig with tube stage pre, Jolida modded cd player (though he scoffs when I ask to use the CD player, as he prefers the sound of good old vinyl), gigantic legacy towers??? No, but I am not ashamed to have him over to hear my humble setup now that the AVR has been relieved of amp duty. I have a nice tidy setup, that allows me to listen to anything, movies, 2ch, SACD, Vinyl, stream from my PC, etc. This isnt the final stop on my audio journey; it is merely a pit-stop on the road to aural bliss.
    Once I am done schooling, however, I would like to have a dedicated 2CH setup in ADDITION to the multi-purpose,hometheater setup I have now.
    Just my opinion, of course. :)
    [The Ever-Evolving System
    LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
  • reeltrouble1
    edited May 2010
    Jer.War wrote: »
    oooh the force is strong in this one, I sense great things for you.
    RT1
