Center image smearing on 2.3TL's...
    F1nut Posts: 51,747
    edited May 2010
    Am I crazy for thinking the harshess has been deminished from the SL3000's by removing the poly's???
    Yes, you are crazy. If anything, the tweeters should be brighter because you just removed a .5 ohm of resistance from the circuit.
    Just taking a cap and putting it on MM won't tell you anything.
    My Fluke 177 measures capacitance as well.
  • Face
    Face Posts: 14,340
    edited May 2010
    Jesse, it's possible that the poly was adding distortion, hence why it now sounds less harsh.
    F1nut Posts: 51,747
    edited May 2010
    Face wrote: »
    You've got a point there, Mike.
    nooshinjohn Posts: 25,913
    edited May 2010
    Face wrote: »
    Thanks for that Face... Sanity intact!:D:p
  • hangon
    hangon Posts: 228
    edited May 2010
    I bi-amped mine just yesterday, what a huge improvement in clarity.
    I was hearing before the bi amp the tweeters were dimming when the bass
    was hitting shrinking/changing the sound stage. I am using them in a theater set up with out the interconnect cable connected, my opinion it sounds better with out it connected.
    I am saving coin $$ for the crossovers upgrade, this is next on my list.
    HT Theater
    SRS-SDA 2.3tl RDO's
    Custom Center made out of a RTA15tl
    Pioneer Elite SC-25 Receiver
    CineNova Grande 5 channel Amp
    Klipsch KA-1000-THX Sub Amp
    (2)Klipsch KW-120-THX Subs
    Basement System
    SRS-SDA 1.2 upgraded Xover
    ADCOM GFA 5500
    ADCOM GFA 5503
    Yahama P7000S Pro Audio Amp
    dbx 120x-ds Sub-harmonic Synthesizer
    2-JBL 4645C Subs
    1-Paradigm SW2200 Sub
    Klipsch Reference in wall's
  • Face
    Face Posts: 14,340
    edited May 2010
    I wouldn't go that far! :D
    Toolfan66 Posts: 18,039
    edited May 2010
    hangon wrote: »
    Is it just me? Why own a set of SDA's if your not going to use them as SDA's?*
  • Schurkey
    Schurkey Posts: 2,122
    edited May 2010
    hangon wrote: »
    CHECK THE RESISTANCE between your - terminals on the amp.
    I had my SDA cable disconnected for a long time--until I figured out that my amp was only "semi" common-ground; there was ~20 ohms resistance between the negative posts.
    A jumper wire between the - posts made a GIGANTIC improvement in sound quality when the SDA cable was in place!
    'Cause they still sound good even without the SDA effect. Good bass, good midrange. Not to thrilled with the treble until I re-capped, RDOd, and added a ribbon supertweeter, though.
  • hangon
    hangon Posts: 228
    edited May 2010
    Schurkey wrote: »
    I just checked my amp, I am getting a reading of (1) ohm's to chassis ground and (0) ohm's between negative posts.
    The manufacture said that it is a non-common ground amplifier, now I am confused.
    I want to try the interconnect cable but, I am a little Leary.
    HT Theater
    SRS-SDA 2.3tl RDO's
    Basement System
    ADCOM GFA 5500
    ADCOM GFA 5503
    2-JBL 4645C Subs
    F1nut Posts: 51,747
    edited May 2010
    hangon wrote: »
    I was going to say that you definitely have something wrong with your speakers until I saw you post,
    You cannot use a non-common ground amp with your SDA's unless you use the AI-1 SDA interconnect cable or you are able to strap the negative outputs together.
    It's no wonder they didn't sound right with the cable connected. It's also a wonder you didn't damage the speakers and/or the amp.
    F1nut Posts: 51,747
    edited May 2010
    Face wrote: »
    You've got another point there, Mike.
  • ben62670
    ben62670 Posts: 15,969
    edited May 2010
    With only 1 ohm resistance you should be able to strap the grounds on the amp.
    Ben
  • FTGV
    FTGV Posts: 3,650
    edited May 2010
    I assume it's the CineNova your speaking of?It appears to have 5 completely separate modules so technically the grounds for each channel are separate,which is likely what the company was meaning non common ground.However your meter readings and the fact that the company says it is stable into a 2 ohm load indictes it does not utilize a bridged/balanced output stage.Therefore the grounds of all channels will be at power supply ground so strapping the negative binding posts should be permissable.
  • hangon
    hangon Posts: 228
    edited May 2010
    Please explain the best method of strapping the Grounds?
    FTGV
    Yes this is the amp I am using.
    HT Theater
    SRS-SDA 2.3tl RDO's
    Basement System
    ADCOM GFA 5500
    ADCOM GFA 5503
    2-JBL 4645C Subs
  • Schurkey
    edited May 2010
    hangon wrote: »
    hangon wrote: »
    You have "0" ohms between the negative posts already. Strapping is pointless.
  • hangon
    hangon Posts: 228
    edited May 2010
    Connected the interconnect tonight for the first time, and what a huge difference in sound quality. I was so afraid to hook it up because of the incorrect information from CineNova.
    This also cured my smearing issue, thanks.
    HT Theater
    SRS-SDA 2.3tl RDO's
    Basement System
    ADCOM GFA 5500
    ADCOM GFA 5503
    2-JBL 4645C Subs
