XPA-5 speakers hookup choice
madnod
today my XPA-5 reached Qatar , didn't try it yet (obviously i powered it on ), what do u recomend, biamp my RTI A9s,or only run 3 channels, or use it for my CSI A6, RTI A9s and my RTI A1(rear surrounds)? and my FXi A4 side surround to run from my Yammy 665?
i have plenty of blu-ray movies to watch/ rewatch now
Post edited by madnod on
I would use it for the front L/C/R and the side surrounds and let the back work off the AVR.
+1
You don't need a lot of power for rear speakers.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
I would personally use a single channel for each speaker, but I've never heard any improvement from biamping.
+2, but try it out in different combinations and see which one sounds the best for you. Congrats on the new toy. BTW, you are in Qatar?
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
wutadumsn23 wrote: »+2, but try it out in different combinations and see which one sounds the best for you. Congrats on the new toy. BTW, you are in Qatar?
-Jeff
yes most probably i'll try the side surrounds and the rear surrounds,
i am a lebanese living in Qatar. -
Surely this is proper bi-amping, i.e. 200w x2 to the fronts?
I'm considering ordering the XPA-5 for my setup - and am considering the same as the OP. -
I'm kinda confused as to what you mean. Proper Bi amping would use two different amps with an external cross over ect. If your using it for pure HT the benfit of bi amping can be limited. if you do it I woudl really only use it for music with 2 channel -
I'm new at this
I thought considering the XPA-5 would provide 200w over two different channels to one speaker - it would be the same as using two 200w amps. -
yes indead the usual 1+1 =2 doesn't work in passive bi-amping, most people they advise that 1+1 =1! i am yet to see soemone explaining it in a scientific way.
