spike
Cthulhu11
How large of spikes did i need to so call SPIKE my sda's
Post edited by Cthulhu11 on
myesound.com go to points n pads
I can not remeber the size. I will try to dig up the link where I spiked my 1Cs.
Go here
http://www.polkaudio.com/forums/showthread.php?t=82792&highlight=spikeSpeakers: SDA-1C (most all the goodies)
You can pay a sh!tload of money for spikes; or you can build your own for under $5 if you have access to a bench grinder and a hacksaw. 1/4" SAE Grade 8 bolts with the heads cut off and the bottom ground to a point, threaded into common hardware-store "T-nuts" will do nicely. Lock each bolt with a jam nut. Six bolts, six T-nuts, six jam nuts will do a pair of speakers.
Spike size isn't real important because speakers aren't that heavy. Even SRS-1s are less than 200 lbs each.
