Center image smearing on 2.3TL's...
nooshinjohn
nooshinjohn Posts: 25,884
edited May 2010 in Vintage Speakers
I was wondering if anybody else has had this problem with the large SDA's. The trouble simply put is that although the speakers sound fantastic overall, the sound that comes from the center area of the soundstage(vocals or instruments) are fuzzy at best and on poor recordings, are smeared and deeply resessed in the soundstage.
The placement of the speakers appears to NOT be the cause as I have tried them in several positions. Currently they are 8" off the back wall, spiked, and 3'4" off the side walls with exactly 6 feet between them. The listening position currently 7 feet from the front of the speakers, but at all distances, whether 5 feet or ten feet, the center images and blurred. All drivers are functioning perfectly, as are the SL-3000 tweets. The crossovers are stock.
I have upgraded to a Rogue Audio Perseus Tube Preamp, and this has helped somewhat, but I still lack cohesiveness in the center.
Any ideas here guys?
Post edited by nooshinjohn on
    Tony M Posts: 11,577
    edited May 2010
    Have you checked the wire hook-ups on the mid-woofers?
    I had one wired wrong on one of mine. I was informed by a friend that saw it was pulsing in when the rest were coming out.
    I noticed yesterday that I had a pos. speaker wire not even attached to my amp. The balance was a little more to the left and the sound was ok BUT not quite right. I had a little trouble with that wire a week ago moving things around and so I thought about looking in the back and sure enough, the pos. was just floating in air but the speakers played pretty well.
    But when I put it back in....BAM...pure clarity again with dead on center stage vocals.. :D
    Good luck to you finding your weak link.
    edited May 2010
    I have verified all connections at the amp, speakers and the interlink. Internally, all appears good there as well
  • Conradicles
    Conradicles Posts: 6,331
    edited May 2010
    Very interesting John. The center stereo image is the strong point of my smaller SDA-1C's.
    Do you notice this same situation with well recorded CD's?
    edited May 2010
    Yes... It does not matter what material or source I use. It is always present to some degree.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2010
    Get some better speakers.:)
  • lightman1
    lightman1 Posts: 10,796
    edited May 2010
    I'll take 'em off your hands for $100 and part them out if you want..........
  • zarrdoss
    zarrdoss Posts: 2,562
    edited May 2010
    Maybe a bad cap in your x-overs? Mine sounded better the further apart I put them about 8-9' right now.
    edited May 2010
    lightman1 wrote: »
    My foot.... your ****.:p;):D
    edited May 2010
    zarrdoss wrote: »
    I cannot get them any farther apart right now than where they are, and I have given thought to the crossovers being the likely cause. I was hoping someone here has experienced what I am talking aboutand could say definitively what they did to solve the problem before I toss $300 bucks at crossover mods and another $300 at RDO's.:confused::cool:
  • NotaSuv
    NotaSuv Posts: 3,871
    edited May 2010
    maybe bigger isn't always better.................speaker wise that is
  • Face
    Face Posts: 14,340
    edited May 2010
    Did you have a solid center image with any other speakers?
  • Face
    Face Posts: 14,340
    edited May 2010
    Those are things you should have taken care of before going through different pieces of gear to find better synergy. Bite the bullet already!
    FYI, upgraded crossover parts can improve imaging.
    edited May 2010
    Face wrote: »
    My LSi-15's are better in this regard, but the 2.3s are better in everything else.
    Face wrote: »
    I am leaning towards that sentiment as well, but am hoping someone with experience with the upgrades can confirm this will make a difference for the problem I am experiencing.
  • erniejade
    erniejade Posts: 6,321
    edited May 2010
    This might sound crazy but, on some music, the SDA cable,,, just messes with it.. On some LP's or cd's I unplug the cable and it all comes back. While I do love the SDA effect, on some recordings it kind of kills it or makes it almost sound like it is out of phase in a way.. Hard to explain.
    On a different note, what kind of CD player are you using? I have a friend that is running 1.2's and a theta dac and he was running some kind of time align jitter unit, .. Well, it sounded terrible on the SDA's the sound stage was off and just didn't sound right... Took the jitter unit out and the time thing and just ran it with the DAC problem solved.
    F1nut Posts: 51,687
    edited May 2010
    It's not the design of the speakers and your set up is spot on, so I'd check for weak/bad tweeter(s) and/or crossover issues.
    heiney9 Posts: 25,408
    edited May 2010
    Face wrote: »
    Absolutely and absolutely.
    Toolfan66 Posts: 17,992
    edited May 2010
    What does one use to check a cap and/or resistor?
  • Face
    Face Posts: 14,340
    edited May 2010
    An LCR meter.
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    A digital multimeter should work too.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
    edited May 2010
    You need an ESR meter to check the caps as they are in the circuit and operating. Just taking a cap and putting it on MM won't tell you anything.
    see this post.
    http://www.polkaudio.com/forums/showpost.php?p=1332336&postcount=5
    Just replace the damn things, they most likely need it anyways. Do the RD0's as you have funds.
  • ESavinon
    ESavinon Posts: 3,067
    edited May 2010
    My 2.3TL have perfect center imaging and I have yet to do tweeter and crossover upgrades.
    Check your crossovers. If you have an issue with mid recessed imaging, You may have defective crossovers.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • ben62670
    ben62670 Posts: 15,969
    edited May 2010
    Bobsama wrote: »
    It won't most likely read caps. You need a special meter to read inductance and capacitance. None will tell you sound quality.
    Ben
    edited May 2010
    Thanks for all the support guys. This place is the best!:)
    I did some homework, with the information you guys provided, and decided the crossovers are the place to start. The most annoying part of the original crossover is no doubt the polyswitch, so I bypassed the switch using the method suggested by Ben(thanks for the call bro) and reinstalled the crossovers.
    Imaging problem SOLVED!!! :D:D It is as others have said countless times before. The veil has been lifted and the difference in clarity is night and day. If the crossover upgrades are anything as dramatic as this, I will be sending them out by the end of the month!:D
    edited May 2010
    John IMO you have waited too long already.. My 1.2's only had about an hour of playing time before I tore them down for the upgrades, as well as my 1C's.
    I love ya bro but get it done already....
    edited May 2010
    ^^^Lol, yes SIR!
    I am saving the coin for them now.
    edited May 2010
    Am I crazy for thinking the harshess has been deminished from the SL3000's by removing the poly's???
    edited May 2010
    WTF, weren't the 1C's you sold Dave modded? If so, you should know how dramatic the change is.
    edited May 2010
    The poly's were still in place on those...
  • FTGV
    FTGV Posts: 3,650
    edited May 2010
    heiney9 wrote: »
    It can tell you if it is either shorted or open,and some meters like my Fluke 175 can measure capacitance.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2010
    Crossovers & RD0 upgrades are what will take care of this "issue" John.
