Grado PH-1 phonostage: good or ok or NOT!
ALL212
Does anyone here have experience with the Grado PH-1 phonostage? I'm using a Music Hall pre now with a Music Hall MMF 5 turntable and may have an opportunity to acquire one of these.
Thanks!
Aaron
Thanks!
Aaron
Aaron
Enabler Extraordinaire
Post edited by ALL212 on
No personel experience but I've read nothing but great reviews about it.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
I like the rolls-bellari better and it's a little cheaper @ MSRP. Worth it if you're getting a deal, dunno if it's better than the Music Hall.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
I am sure it's a good product but the Grado is awfully 'spensive for what it is.
Can you solder? :-)
http://www.hagtech.com/bugle.html
http://www.bottlehead.com/store.php?crn=220&rn=429&action=show_detail (this is the one I use, FWIW)
http://www.hagtech.com/cornet2.html
