Parasound HCA-2205A
dpowell
dpowell Posts: 3,081
edited May 2010 in Electronics
I'm looking for input from anyone who knows or has heard the Parasound HCA-2205A power amp. I have an opportunity to pick one up locally. It is 220wpc @ 8ohms and 300wpc@ 4Ohms.
Post edited by dpowell on
  • Dawgfish
    Dawgfish Posts: 2,554
    edited April 2010
    This is a really good sounding amp from a really good company. If you found a good deal on one, I would jump all over it. They have a really detailed sound with nice soundstage and imaging, without being harsh. The sound leans more towards the neutral to just slightly warm side of things meaning they sound good with a lot of different pres and sources. Great amp! Jump on it.
  • TG Meat
    TG Meat Posts: 159
    edited April 2010
    I too am a big fan of Parasound. Local buying is always nice...try before you buy.
    Anthem D2v
    NAD M50 Music Server
    B & K Reference 200.5
    Parasound A21
    B & W 804 (Mains)
    B & W HTM1 (Center)
    Polk Rti4 (Surrounds)
    PS3
    Seaton Submersive HP
    Pioneer PDP 6010FD Kuro
  • kevhed72
    kevhed72 Posts: 5,165
    edited April 2010
    I know I would like one....let me know if you pass on it.
  • Bernal
    Bernal Posts: 991
    edited April 2010
    Hello,
    A friend had one, gave him many problems in 4-ohm speakers.
    RECOMMENDED then tested with 4-ohm speakers
  • Amherst
    Amherst Posts: 695
    edited April 2010
    I have been running this amp for several months now, no problems what so ever. I would classify it as pretty neutral sounding with a ton of balls...all five of them. No issues driving 4ohm LSi's.
    Parasound C1, T3, HCA-3500, HCA-2205A, P/DD1550, Pioneer DV-79avi, Oppo BDP-83, WD Media Server W/HDD,
    Dynaudio Contour 3.3, Dynaudio Contour T2.1, Polk OWM3, Polk DSW micropro 1000 (x2),
    Pioneer Kuro 50" Plasma, Phillips Pronto Control w/Niles HT-MSU.
  • kevhed72
    edited April 2010
    I have been looking for a neutral to warm sounding AMP for 2-channel / HT use for a while now to drive my RTiA series, and I think the 2205 may fit the bill.
  • cstmar01
    cstmar01 Posts: 4,424
    edited April 2010
    its a good amp. I was looking at the 2250 for awhile which is like this. good amp for a good price IMO.
  • dpowell
    edited April 2010
    I'm trying to decide if I should pony up the $800 (or offer less) (once I find out what the bill is going to be to get my Pioneer AVR fixed) or wait for a deal on a Parasound Halo A51 which from my research seems to be the holy grail of Parasounds.
  • Amherst
    Amherst Posts: 695
    edited April 2010
    If you can pick it up for $800 working....don't flinch.
  • megasat16
    megasat16 Posts: 3,521
    edited April 2010
    dpowell wrote: »
    I have 3 of HCA-2205AT which I used with LSi speakers for HT. They rocks the house and I found them nice sounding with LSi series. I have tried Adcom and Rotel but I like HCA-2205AT best for my HT room.
    Now, you just make sure the amp works well and tested it for about 30 minutes. This amp runs warm to hot so if there is any problem, it usually shows up in 20-30 minutes of usage. One of my amp is giving me trouble when it's running Hot. If you do buy it, use it in well ventilated area.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • dpowell
    edited April 2010
    megasat16 wrote: »
    Thanks, good to know. Unfortunately, the destination for the power amp is inside my cabinet. I have 2 fans running on my Adcom right now (which doesn't really run too hot) and I keep the door adjar when running at high volumes. Not much else I can do in my situation.
  • anhchungdoan
    anhchungdoan Posts: 760
    edited May 2010
    Bernal wrote: »
    Hello,
    I have owned the Para 2205ATonce and it drove my MLs ( SL3 front, Cinema center, Aerius I rear) just fine. The Sl3 can drop below 2 ohm. The only " flaw" in design is the 5 set of binding posts are to close together so spade lugs are not an option.
    SQ wise, it's damned good.
    I bought it new in box and Para does not make another just like it any more. If memory serves me well, believe the transformer size is 2 KAV as heavy duty as the Krell KAV250.
