I need more amps!
GoBlue
GoBlue Posts: 30
edited April 2010 in Electronics
Im really starting to get into the home audio world, and I think its time for some additional amps. I dont know what to get, as Ive never been in need of such things before. What should I do?
I just purchased Acoustic Research AR9's, the newer ones. They are bi-amp capable, and the 10" side firing subs are rated at 250w peak power. The subs themselves are not powered, so that is why I think I need an amp, or two.
My receiver is a Pioneer Elite, VSX-55TXI, and that is what I am planning to run the mids, and highs with.
So, do I need additional amp(s), because I think it would sound a lot better with them, and which types should I consider?
I can always provide additional info, if needed.
Thanks.
Theater:
Pioneer Elite VSX-55TXI
Adcom 555
Acoustic Research AR9 (Latest)
JBL S Center
Definitive Technologies ProCinema 1000 (Surround x2)
JBL PS1400 Sub
Monster 3600 MkII Conditioner
NAD T572 DVD
PS3
Lots of wire
-Looking for a decent Sunfire MK II-
Samsung LNT-4665F
Polk OMW3 - TV Speakers
Vintage:
Pioneer SX-780
Pioneer PLA-45D Turntable
Advent Heritage Speakers
Post edited by GoBlue on
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited April 2010
    A budget for the amp would be helpful. Also i would get an amp and run everything off of it, not the bass driver on the amp and mids/highs on the Pioneer. This can cause problems.
    If you really want to bi-amp you need to run two amps that are the same model so everything will be the same and no imbalances will come into play.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • GoBlue
    GoBlue Posts: 30
    edited April 2010
    From $200-$300. I am willing to go used.
    So idea no. 1 is just wire both speakers into one separate amp? How come you cant wire the mids and highs in the receiver if they are separated?
    Idea no. 2 makes sense, to use two of the same amps, but do I need two? I dont need to bi-amp, thats just what I thought would be a good idea. Thanks again.
    Whats the smartest and safest way?
    Theater:
    Adcom 555
    JBL S Center
    JBL PS1400 Sub
    NAD T572 DVD
    PS3
    Lots of wire
    Samsung LNT-4665F
    Vintage:
    Pioneer SX-780
  • logo896
    logo896 Posts: 322
    edited April 2010
    How much rms do those towers take, if you watch onkyo's website the sell direct from them a refurbished m282 i think they are called that gives you about 100 rms x 2 @ 8ohms.
    http://onkyousa.com/model.cfm?m=M-282&class=Amplifier&p=s
  • logo896
    logo896 Posts: 322
    edited April 2010
    Btw you could always go with a Emotiva Upa-2 which would be another good choice in your price range, these are both good picks if you dont want to buy a used amp.
    http://emotiva.com/upa2.shtm
