OPPO BRP and Avatar
NeilGabriel
Posted this in Music/Movies, but this gets more hits!
Avatar is the first movie in 6 months the OPPO would not play. The movies warns about the need for firmware updates. Has anyone had to do this? Or should I just try another disc? After loading and then giving the Columbia ( I think) Pictures intro, it goes to Top Menu with black screen and no button works except eject.
Post edited by NeilGabriel on
NeilGabriel wrote: »Posted this in Music/Movies, but this gets more hits!
Firmware Release:
Latest Version
Release date: March 29, 2010.
Category: Public Beta Version
Main Version: BDP83-50-0323B
Loader Version: BE2690 or BT0390
Sub Version: MCU83-27-0326kuntasensei wrote: »I can confirm that Avatar plays flawlessly with the latest firmware. -
I had this happen with another movie. A firmware update took care of the problem.
If you have BD Live enabled, try disabling that, and see if that works. It works for some titles.Samsung HL61A750 LED DLP
Onkyo TX-SR805 receiver
Oppo BDP-83 blu ray player
Polk Audio LSi9 front speakers
Polk Audio LSiC center speaker
Sony SS-MB100H rear speakers
SVS PC12-NSD powered subwoofer
Pioneer PL-514 turntable
Logitech Harmony 628 Universal Remote -
Is the easiest way to get the update to hook up my laptop to the USB port on the BRP and go to OPPO for the update? Thanks.
It seems like this takes a different usb connector with the wide end on both ends (whatever the wide end is called----out?) have to see if I have one... -
I actually read the manual and see that I need an ethernet cable... i have everything but as the only one in the house is needed for the wireless router....jeeez....thanks for the help though....
check your manual.....my panasonic will let you do an update if you download it to your computer, burn it on a disk, and then run it in the player."Making life enjoyable through expensive electronics." BillD
Pioneer Elite SC-57
M70 series 2 mains
CS2 center
M40 surround
M30 front height
SVS PB 12 NSD
Carver TFM-45 (mains)
Carver A753x (center, surround)
320GB PS3, 42" Panasonic G10,
M60's as a Zone 2 off of the Pioneer in the living room
R.I.P. Onkyo TX-NR807 -
Couldn't get my Avatar to play on my Pioneer. This is where my ps3 excel, wireless downloads.
Played back perfectly on my Oppo. Use a thumb drive as it is the easiest. The Oppo won't download beta firmware so you'll either have to burn to CD or USB thumbdrive. I prefer thumbdrive so I'm not sitting here waiting for a burn. Simple and easy, but download the latest, I'm running the beta software and everything plays fine.Shoot the jumper.....................BALLIN.............!!!!!
thanks....the manual actually says to use the ethernet cable...when that failed, I probably would have broken something....
True, but once you load the beta firmware, it will then auto-notify and download future beta firmwares if you're connected to the 'net.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
kuntasensei wrote: »True, but once you load the beta firmware, it will then auto-notify and download future beta firmwares if you're connected to the 'net.
Oh good info, I didn't know this, thnx bro!Shoot the jumper.....................BALLIN.............!!!!!
I knew this sounded too easy. I have downloaded both updates. I then burned with Sonic and then on a different disc with the Toshiba burner. All I get to burn is the same single icon with the .iso file type. I do not get the several files that OPPO says should be burned to the disc.
I gather this might because I am not burning as an Image Disc....?....I knew data and audio....and tho9ugh image was part of data....help????
The Sonic burner does not give an Image to Disc burn option and the Toshiba keeps giving me an error message (unexpected error, of course). -
http://www.imgburn.com/index.php?act=download
Good free burner for ISO images that should get you going.Equipment list:
Emotiva XPA-3 amp
thanks...I updated the Toshiba disc creator.....and got the burn I needed...first update done...now for the beta....isn't beta like a test update?
Yeah, but they're pretty safe. I haven't had an issue yet with Oppo's beta firmwares.Equipment list:
Emotiva XPA-3 amp
kuntasensei wrote: »Yeah, but they're pretty safe. I haven't had an issue yet with Oppo's beta firmwares.
+1, no issues here.Shoot the jumper.....................BALLIN.............!!!!!
