Just bought a turntable -
vmaxer
what is a good starter cartridge?? Here is the TT I got....any thoughts??good or bad:o
http://cgi.audiogon.com/cgi-bin/cl.pl?anlgtabl&1277296024
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
Post edited by vmaxer on
Call Needle Doctor, tell that which TT you have and budget. They will give you some right choices based upon your TT.Speakers: SDA-1C (most all the goodies)
Very nice table. To get into a moving coil on the cheap those Denon's can't be beat. You'll be very pleased if this is your first table.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Nice snag Bro. If you've got a little coin to spend to really get that table singing try the Dynavector 10 x 5. You will be floored. However, they go for around $380.
http://www.needledoctor.com/Dynavector-10X5-Cartridge?sc=2&category=370
Pay no attention to the price listed in the link as you can get it for what I stated above or less. If you do get it, you won't be needing to upgrade the cartridge for a long, long time. It tracks like you wouldn't believe. -
congrats--beautiful turntable--let us know how is sounds in your riig.JC approves....he told me so. (F-1 nut)
That's a nice table! I've heard nothing but good things about those vintage Micro Seiki tables. +1 on the Denon DL-160 cartridge. The Sure M97 is also not a bad starter cartridge that can be picked up for $70 in some places. Having owned both the Sure and Denon, I can say that I like the Denon much better and to me the addtional cost was well worth it.
Ok, I have started looking into this and there seems to be a bit more I need to know..:o
I use a Sunfire TGP 5 processor and it says if I use a moving coil cartridge that it has to be high output
Is this okay or will I need a phono preamp?? Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
The Denon DL-160 is a High Output MC cartridge. Not sure about the others listed.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
hearingimpared wrote: »Nice snag Bro. If you've got a little coin to spend to really get that table singing try the Dynavector 10 x 5. You will be floored. However, they go for around $380.
Thanks, that sounds good. I haven't been able to find one for less than 430.00 ??? Where can I find one at the price you listed??Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
The processor has a MM level phono input that will handle High Output Moving Coils (i.e. Denon DL-160 @ 1.6 millivolts (actually rumored to measure higher)) but not the Low Levels Moving Coils like the DL103. I second the DL160 for its price but the suggestion of the Dynavetor 10x5 is a great value for the dollar also.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
First off it is a high output moving coil cartridge, 5mv. Secondly, you can call all the distributors of the Dynavector line and haggle with them if you are so inclined. The thing to do in this case is call the dealer ask for their best price then go to the next expressing that you can get for $xx.xx at so and so and keep going until you get it down to price you are comfortable with. They sold for $380 new a couple of years back and I got one using the method above for $335.
I have seen used ones for as low as $200 but they are far and few between. Audigon, ebay, vinyl asylum etc. Google "used Dynavector 10 x 5 cartridges" and see what pops up.
The problem with buying used is that you have to get the seller to agree, in writing, that if there is anything wrong with it, you get you money back. Also get in writing if you can how many hours the seller has on the cartridge, maybe ask what kind of TT/tonearm combo he used.
ON the up side of buying used the cartridge and cantilever are usually already broken in so there is no waiting period of at least 35 hours where while waiting for it to loosen up you keep thinking you made a mistake because it usally will intermittently sound lousy until it does lossen up.
Good luck,
Joe
PS: I'll keep my eyes peeled for you. -
Congrats on the table. I have a DD-40, BL-51 and a BL-91L . They are good tables for the money. The Denon 160 or the Dynavector carts would work great. You need a clamp, too; such as the ClearAudio.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Polkersince85 wrote: »Congrats on the table. I have a DD-40, BL-51 and a BL-91L . They are good tables for the money. The Denon 160 or the Dynavector carts would work great. You need a clamp, too; such as the ClearAudio.
AMEN however not the Clearaudio Clear Clamp is it truely a POS! Get the Clearaudio Twister Clamp. You'll be stunned at the improvements it makes and is worth every penny of the $100 price tag.
http://store.acousticsounds.com/d/36249/Clearaudio-Twister_Clamp-Record_Mats_and_Clamps
Let me add that there are several dealers of this clamp so you should be able haggle down the price a bit. Google "Clearaudio Twister Clamp" and you'll get a list of all the dealers. TALK THEM DOWN!!!
Well, I bit the bullet and ordered a PS Audio GCPH phono preamp...Anyone know about it?? Opinions on it please both the good and bad as I have 30 days to return if not happy:)Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I've always heard and read good things about the PS Audio phono pre, but no personal experience. The SimAudio LP3.5 is another great phono pre, and I do own one of those.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
I think that is the best pre you will get for the price. Heard it on another system and it was awesome. Are you sure you have not done this before? Excellent choice!
madmax
Edit: I also recommended that same one to a friend a few months ago.Vinyl, the final frontier...
madmax
Never before, but I read a lot here and can't recall any bad reviews on PS Audio... Got it for a great deal and have 30 days to return. I also like that it has a sub sonic filter and can be connected directly to an amp and has a remote control...:cool:
I meant to go easy into this, but reading here is directly connected to the wallet I think as I can't keep anything in mine if I spend any time here:eek:Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Well, I bit the bullet and ordered a PS Audio GCPH phono preamp...Anyone know about it?? Opinions on it please both the good and bad as I have 30 days to return if not happy:)I've always heard and read good things about the PS Audio phono pre, but no personal experience. The SimAudio LP3.5 is another great phono pre, and I do own one of those.
Like Doug, I've read lots of great stuff on the PS Audio phono pre but have no experience with. PS Audio does make some great gear and accessories. So with the 30 return policy I think you did good.:) -
You might as well buy what you want because in the vinyl world you will end up buying it at some point anyway.
okay, I am still gathering needed items for this seup. I am now finding myself in need of 2 sets of cables, a set to the phono pre and from the phono pre to the processor.. What are some good and reasonable cables for this. I am leaning toward signal cable - http://signalcable.com/silverresolutionphono.html
Opinions please..suggestions:o
Currently using to old Onkyo turntable listening to Dire Straits frst LP.....:cool:Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Signal Cable is a fine place to start Bro. Make sure you specify one set of PHONO cables and one set of ICs when you place your order. -
hearingimpared wrote: »Signal Cable is a fine place to start Bro. Make sure you specify one set of PHONO cables and one set of ICs when you place your order.
Okay, I am confused
...what is the difference?? Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
hearingimpared wrote: »AMEN however not the Clearaudio Clear Clamp is it truely a POS! Get the Clearaudio Twister Clamp. You'll be stunned at the improvements it makes and is worth every penny of the $100 price tag.
Ordered.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
you might as well buy what you want because in the vinyl world you will end up buying it at some point anyway.
madmax
+1
JC approves....he told me so. (F-1 nut) -
Okay, I am confused
A phono cable goes from your tonearm to your preamp or phono preamp. It is usually designed with a separate ground wire as well as a din type connector with five female jacks on it to fit into the bottom of your tonearm with the separate ground wire on the other end with a spade running along side two RCA connectors.
The IC's are for making line level connections for such things as going from a phono pre to preamp, preamp to amp etc etc. they have two male RCA connectors on each end and are grounded by the outer ring of the RCA connector.
Hope this helps,
Joe:)
Just to clarify further;okay, I am still gathering needed items for this seup. I am now finding myself in need of 2 sets of cables, a set to the phono pre and from the phono pre to the processor.. What are some good and reasonable cables for this. I am leaning toward signal cable - http://signalcable.com/silverresolutionphono.html
"a set to the phono pre" would be the phono cable I described and "from the phono pre to the processor" would be the IC I described. If you're still fuzzy on the matter, PM me and I'll try to make it clearer through discussion there. -
The MA-505 arm on that table is just like mine. There are RCA jacks at the base of the tonearm. RCA ICs will work just fine.>
Thanks all, Mine is like Polkersince85 has.:)Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Polkersince85 wrote: »The MA-505 arm on that table is just like mine. There are RCA jacks at the base of the tonearm. RCA ICs will work just fine.Thanks all, Mine is like Polkersince85 has.:)
That's great, however do you just add a ground wire from the ground post there to the ground post on the phono pre. Also there are cables with the ground wire running along side made just for phono connectons like that. I believe they are shielded better due to the low voltage of the cartridge output. -
Okay, I am confused
For all the IC's in my rig I'm using Ben's silver cables which, not even fully burned in sound great. But when I tried to use a pair for TT to pre I got a slight buzzing even with a ground wire on. A phono cable has proper shielding to prevent and external components causing interference or noise.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
Not to mention the phono cables propensity to pick up RFI & EMI from radio stations and home electrical appliances, refridgerator motors come to mind due to what I noted above.
Ben's cables are great but we went round and round trying to get rid of the hum I got using his cables in my phono cable path. He made me a star quad cable which did in fact reduce the hum but never got rid of it. A lot had to do with the step-up xformer I was using in lieu of setting the gain higher in my phono pre. -
Okay, I am confused
"Phono" cables from the TT to the PS audio pre(it's an interference/shielding thing)I like the VPI phono cables in mine,,you can find them on A'gon reasonably priced,but they go fast,,I'm currently lookin for some Van den Hul "first ultimate" ,,BTW,,the PS Audio pre that you picked has been quite the rave and,according to the experts?(grain of salt),,has quite a nice upgrade/mod path.Seems as though you've assembled a very nice vinyl front end,,enjoy.
