Is amp good enough?
Mike
I am thinking of buying a Hifonics NX 880 100 x4 @ 4 ohms. Then get some Polk speakers. My choices are:
1. EX 369 (100 w) and EX 365 (60 w)
2. DB 690 (100 w) and DB650 (60 w)
3. DX 9 (50 w) and DX 6 (40 w)
My question is: Will this amp drive all of these speakers nice or would I need a smaller amp if I go with the DX's? Or a bigger amp for the other two?
Post edited by Mike on
what about a 100x2 and a 50x4?
-Cody -
I was trying to keep it as simple as possible, and keep it cheap. I'm going to do this to 2 cars.
sorry, i completely misread your post...go with speaker option number 2
and yes, that hifonics will do
-Cody -
I agree. Hifonics is a very good amp and will give you a nice clean signal. Ive heard nothing but good things about them.Testing
Testing
Testing -
Thanks everybody. I just ordered 2 Hifonics NX 440's. They are on their way. I've decided to put DB's in one car and EXiii's in the other. Now I have to order them, as soon as I find the best price.
try www.acaraudio.com
www.electronicscity.com
www.carmedia1.com
www.thezeb.com
www.sounddomain.com
www.onlinecarstereo.com
one of those sites will have it the cheapest that i could find...im not sure if all carry hifonics, and im not sure carmedia1 is an authorized dealer, but the rest are
also, www.carstereotime.com isnt an authorized dealer, but they come with a 1 yr warranty through carstereotime, that would be my LAST choice, and unless theyre more than $20 cheaper, i wouldnt go with them
-Cody
