Upgrade monitor 50's
I am currently running 2 RTi 6s, a CSi 3, and 2 Monitor 50s and a PSW 111 on a Denon AVR 788.
I am trying to figure what to upgrade my Monitors to and I can't figure it out. I thought about a pair of RTI A1's I found online, but I could use some help.
Bez
Bez
My 5.1 System:
Fronts: Monitor 50s
Center: CSi 3
Rears: RTi 6s
Receiver: Denon AVR-788
and thanks monoprice for the wires
Fronts: Monitor 50s
Center: CSi 3
Rears: RTi 6s
Post edited by scrmdm12 on
Bez
Let me know what you want for the 50'sReceiver - Onkyo TX-SR805
Mains - Polk Audio Monitor 70
Center - Polk Audio CS2
Surrounds - Polk Audio Monitor 40
Subwoofer - Polk Audio PSW505
Television - 60" Mitsubishi WD60737
Bluray - Sony BDP-S360
Gaming - Xbox 360 Pro 60 Gig -
really not helping dude but will doMy 5.1 System:
Fronts: Monitor 50s
Center: CSi 3
Rears: RTi 6s
and thanks monoprice for the wires -
Rti-6s are better Rti-A1s because they are the old Rti-A3s.
Do you want to upgrade to another tower or stay bookshelf? The natural upgrade for you would be Rti-8s/A5s which are the entry tower that matches your center and bookshelves.
You can get a pair right now on Polk's ebay site for 359 which is an absolutely fabulous price. Use the Rti-8s, Csi-3 upfront...move the Rti-6s to surround duty and you're definitely up a notch from what you had before for not much coin.
Well I would prefer to shrink down a bit and go for the bookshelf if possible, but I suppose you will just tell me to just find another set of A3s or Rti 6s?My 5.1 System:
Fronts: Monitor 50s
Center: CSi 3
Rears: RTi 6s
Yep!
