Tube Amps to Drive SRS 1.2TLs
toucanet
toucanet Posts: 581
edited May 2010 in Vintage Speakers
As many of you know, I recently got my hands on a pair of SRS 1.2TLs to replace the ones I lost in a flood.
Now that I've had a chance to listen to these speakers with different preamps and amplifiers, I still have not been able to hear the sounds come out of these speakers the way they came out when I listened to them in beemers417's shop. They were hooked up to a single VTL (don't remember model) amp and sounded really great. While I am in no way saying that they don't sound great with my current equipment, I am saying that the sounds from the preamp (Jolida JD50A) and tube amp at beemers417's shop really made these speakers come alive.
Sounds like I've been chasing a natural high of some sort. Damn you beemers417!:D
Here is a list of the gear that I have used to listen to these speakers so far:
1. Carver CT-17 Preamp and TFM-55 Amp - The Sonic Holography does not sound that good with these particular speakers.
2. Jolida JD50A Preamp and A-760 Amp - I really enjoyed the sound from the Jolida Preamp compared to the CT-17 Preamp.
With this being said, if you were looking for a preamp and tube amp(s) to power your 1.2TLs, what would be your top choices based on a budget not to exceed $10,000? The room dimensions shall be 20 feet by 30 feet (ceiling height is 18 feet). Feel free to include hybrid preamp(s) and amp(s) as alternatives.
I'm curious.
Post edited by toucanet on
  • george daniel
    george daniel Posts: 12,096
    edited April 2010
  • Pycroft
    Pycroft Posts: 1,961
    edited April 2010
    I can't comment on specifics, because I've never listed to the high end tube amps or preamps, but FYI, there is a guy local to me who has two BAT 75SE amps - 75 watts each of tube power, and retail for 10k each. I think he would let them go for 3k each, or if you buy both, probably less.
    If I had 10k, I'd spend it on them :)
    James
    2 Channel/HT:
    Sony SS-M9 P's (ES version)
    Sony SS-M1CN Center Channel
    Polk RT800 Surround Speakers
    Odyssey Stratos Dual Mono Amplifiers
    TAD 150 Signature Tube Preamp
    Harman Kardon HK354
    Sony SACD Player
    nooshinjohn Posts: 25,916
    edited April 2010
    I am currently running a Rogue Audio Perseus tube pre in my rig and the SDA's are magical with this combination.
  • george daniel
    edited April 2010
    Just a thought,, if you go with mono's, you'll need the AI-1 non common ground interface if applicable/compatable with your SDA's. I drove a pair of 2.3tl's with 100 tube watts very well,YMMV,Good luck.
  • thsmith
    thsmith Posts: 6,082
    edited April 2010
    what is the efficieny rating of 1.2TLs ? 91db ?
    F1nut Posts: 51,749
    edited April 2010
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2010
    Musical Fidelity kw 500 hybrid integrated amp. You should be able to pick up a used one for well under $10K.
    You could also go with a MF Trivista 300 hybrid integrated amp. These typically run around $3k.
  • toucanet
    toucanet Posts: 581
    edited April 2010
    Thanks to all of you. You have given me some very good insight that I will research and possibly pursue shortly.
  • Huh What?
    Huh What? Posts: 55
    edited April 2010
    If you're interested I have a VTL 5.5 with phono stage I'm letting go at $2200 obo. I've got it paired with a Nakamich PA5 and 1.2TL's (all up for sale). PM me if you'd like more info.
    Home Theater - Talon Firebird (Fronts), Talon Raven 2002 (Surrounds), Talon Cinema Hawk (Ctr), Talon Falcon (Back Surrounds), JL Audio Fathom F112 Sub
    Pre/Pro - Classe SSP-800
    Amps - Sim Audio Moon Titan 5 channel, Modwright KWH 225i
    Blu-Ray - Oppo UDP-203
    Projector - Epson PowerLite Home Cinema 5040UB
    Screen - Silver Tickets MPT 110"
    Primary 2 Channel - Talon Firebirds
    Modwright KWH 225i Integrated Amp
    Oppo BDP-103, Audio Research DAC 8
    Secondary 2 Channel - Polk SDA 2B
    NAD T775, Denon 2900 DVD-A/SACD
  • vc69
    vc69 Posts: 2,500
    edited April 2010
    Huh What? wrote: »
    Might I ask what you intend to upgrade to?
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • Huh What?
    Huh What? Posts: 55
    edited April 2010
    No upgrade planned for now. I have a home theater setup with B & W and NAD, so that will just have to do for now.
  • toucanet
    toucanet Posts: 581
    edited May 2010
    If you decide to sell those amps again, I promise I will jump on them like a lunatic.
    edited May 2010
    Huh What? wrote: »
    I think you need a few more posts here before trying to sell your stuff;)...
  • george daniel
    edited May 2010
    toucanet wrote: »
    If I come upon another pair,I'll shoot you a pm,,,be ready.;)
  • ChrisA
    ChrisA Posts: 3
    edited May 2010
    toucanet wrote: »
    I'm curious.
    I'd defiantly, for sure bi-amp them. That would mead using two, two channel amps. I'd place each amp near the speaker, using only an arm's lengh of speaker wire.
    bi-amping pays off big time with tubes because you can select the output transforms for each frequency range, you don't have to compromise. It is very hard and expensive to make an OPT have good bass and transparent highs, biamp means you don't need to try.
    I'd design the amps backwards from the output transformers moving back to the power supply. Call be an "old guy" or whatever but I like the Hammond 1650 series transformers. with KT88 or 6l6 tubes. Going into more detail requires knowing how much power you need. But the above can scale up to 250WPC (total 1000W) but that is unreasonable for your room size. I'd think 100WPC would be better. You can select different transformers for the bass and treble sides of each amp. I'd use the xformer on ultra linear mode
    If you don'r know much about amps and can't build or design them, that's OK with your budget you can hire the work out. I'd suggest doing that, the cost of parts could be kept to $500 per channel easy. The major cost will be the transformers. The thing about custom work is to stay in budget don't spec over the top parts. Build with comonity parts and then only later if need be swap out some of the parts.
  • toucanet
    toucanet Posts: 581
    edited May 2010
    ChrisA wrote: »
    Thanks for the advice ChrisA!
    Welcome to the Club:D
