Carver Amplifiers
ibewbrother
I'm aware that Carver is no longer in business...But did they make good stuff?
Is it impossible to get replacement parts? I am looking at a 3-channel THX model and wonder what a good price would be.
Thanks all.....
...Brother
Thanks all.....
...Brother
"Making life enjoyable through expensive electronics." BillD
Pioneer Elite SC-57
M70 series 2 mains
CS2 center
M40 surround
M30 front height
SVS PB 12 NSD
Carver TFM-45 (mains)
Carver A753x (center, surround)
320GB PS3, 42" Panasonic G10,
M60's as a Zone 2 off of the Pioneer in the living room
R.I.P. Onkyo TX-NR807
Pioneer Elite SC-57
M70 series 2 mains
CS2 center
M40 surround
M30 front height
SVS PB 12 NSD
Post edited by ibewbrother on
Carver amps are good IMO. I have several. Parts are hard to come by but Bob Carver and Rita Helm started up a repair shop. http://www.ritasvintageaudio.net/
The 3 channel you are talking about seems to fetch a good amount of money. This amp was produced after Bob left the company but it still is a very good amp. The last few on eBay went for over $700.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
+1 for carver amps... i love my TFM-422-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod -
I own a Carver TFM-25 and a TFM-45 amplifier as well as a Carver HR-772 Receiver a C-1 pre amp, a CT-Seven pre and a Carver C-19 Sonic Holography Generator unit, so yes I think Carver made great gear.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
I have a Carver TX-2 Tuner that I use to pick up KQRS 92.5 from the Twin Cities which broadcasts from over 85 miles away. I use a Radio Shack directional FM antenna and an uninterrupted quadshield RG-6 cable and it works great.
President of Club Polk -
i have the heart of a small boy...i keep it in a jar on my desk. Robert bloch
Psycho!!!!!
I have two Carver amps and have been very pleased with both. One is a THX 2CH model. -
I stated into separate power amps with carvers and I love them. Also it you haven't noticed most people that have one carver piece of gear they have multiple. I have a M1.0t, 2 M1.5t, a C-4000, and a SD/A-490t. But my favorite piece of gear with carver's name on it is my sunfire cinema grand 400x7 thats is a great multy channel amp.If life had more tubes it would be a lot smoother.
Sorry to crap on your thread, but if you like the garbage Carver built, then these pieces of junk may be right up your alley.;):p Just look at the binding posts on these boat anchors....
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=140400767925The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
If only money was no object I would by these and not the cayin mono blocks I'm planning on buying.If life had more tubes it would be a lot smoother.
nooshinjohn wrote: »Sorry to crap on your thread, but if you like the garbage Carver built, then these pieces of junk may be right up your alley.;):p Just look at the binding posts on these boat anchors....
Now those are some sweet amps!!! -
I got the Carver Sunfire Cinema Grand Signature Series 400 amp 7.1. Very good amp for movies but it's also matched up with a Pioneer Elite SC-05 reciever and DeftTech Mythos ST 5.1 so I don't know if the great sound I get is from the amp or the whole package, so I think it matters on what your other equipment is going to be hooked up to it. My system sounds amazing, it just melts you into the couch and you keep wanting to come back for more, it's not bright or taxing on your senses, just silky smoother, peaches and cream baby.
Ah the infamous Carver silver tube.....I bet one tube blows a week! Better by them in stock by the dozen if you plan to keep that amp running at a mere 16 grand--chump change. My Impala didn't even cost that much--but I bought 'used'!
cnh
Actually, I believe they're pretty bulletproof. Some type of unique auto-bias adjustment? Can a tubehead confirm this?TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Aha! So you're the guy sucking up all the Carver gear and driving up the price for the rest of us!
:D -
virtualdean wrote: »Aha! So you're the guy sucking up all the Carver gear and driving up the price for the rest of us!
:D
You need to add me in on grabbing a lot of cool Carver equipment. I have a good start!:eek:Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
reeltrouble1 wrote: »oooooh, that is awesome.
RT1
Well, thank you Ted--it is awsome.
It's the A-500x and I picked it up from Brother Dave here on the forum to do transmission line woofer duties on my hybrid ESL's. It is the perfect mate for the Lightstar Reference amp that powers the panels. -
thuffman03 wrote: »You need to add me in on grabbing a lot of cool Carver equipment. I have a good start!:eek:
I looked at your signature...
You are even WORSE! What do call a Carver Hawg?
A good judge of character.
If you...uhmmm...ever have to sell due to a crisis and need to off that old stuff...like..uh,,,.cheap...let me know..
(heavy sigh) (sob!wail!) I wont ever have a Carver cache like that!
Too many mouths to feed and support..Including the ex's lasting revenge..keeping me broke. But wait...I dont HAVE to eat brand name groceries, generics are (gulp) okay...and they say Mcdonalds is better than ever.....
Fresh meat is NOT good for you...heck, my shoes got miles of wear left..With resoling...
I CAN save the money! I'm back in the game!..So if you see a raggedly dressed, unhealthy looking (from too many Mcdy visits) man holding a mapleshade catalog..its probably me...give him a good price.:D
BlueMDPicker wrote: »Well, thank you Ted--it is awsome.
your awesome too:eek:, THX thing gets me, I am sure your panels have that cert as well...............btw what panels??? something new???
RT1
