monitor 7B's with rebuilt crossovers
    heiney9 Posts: 25,487
    edited April 2010
    I have jumped the fuses on my 5B's. It's very easy to do and it certainly can't hurt the sound. You will just need to watch your volume if you have a less expensive receiver or amplifier.
  • Freak When C
    Freak When C Posts: 231
    edited April 2010
    OK, thanks for the tip. Quick question, my invoice states:
    (2) Axon TrueCap 33uF 250VDC. Is that the same as the Aeon caps y'all were just referring to?
  • Face
    Face Posts: 14,340
    edited April 2010
    Yes.
    edited April 2010
    IIRC, Axon and Solen are the same company. And yes those are fine for their application.
