question about wattage?
nonfilter
nonfilter Posts: 7
edited April 2010 in Electronics
It seems almost every body buys smaller surround and back L and R , compared to fronts, right .
But using dts , in surround mode , or something 3d , is it true that the amp is sending the same amount of wattage to the rears ?
I would like to build a system with 4 monitor 60 , 1 cs20 and A good sub like the 505 something.
What do you guys think?
Thank you ,frank.
P.S. , will be hooked up to PC .
Post edited by nonfilter on
    edited April 2010
    A number of people run an all tower surround system here. It will put a bit more strain on your AVR but there is NO reason to not do this. And yes the AVR provides equal sound to all channels or as much as each needs, if you have 60s back there they will receive the same wattage as the fronts. However there is less INFO back there so don't expect them to sound like your fronts.
    cnh
  • nonfilter
    nonfilter Posts: 7
    edited April 2010
    cnh wrote: »
    cnh
    Doesn't NEO 6 or 5 , reup music pretty much equally across , in this case the 5.1 surround . Not sure .
    P.S. , I have a lot of compressed digital music , some .flac some mp3's .
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2010
    A speaker is only going to draw as much power as it needs at any given time...it's not as if each channel is receiving 100 watts(for instance) at all times. Most of the time, each channel is probably using no more than 2-3 watts at any given time.
    Running towers as surrounds is definitely "better", but the improvements are going to be minimal IMO. Surround speakers generally carry much less information than the other speakers. The center channel carries roughly 50% of the soundtrack, and nearly all the dialogue, and the front L/R carry nearly the entire musical score. The surround speakers are more or less for ambient sound effects, and don't place anywhere near as much of a demand on your amp of the front L/C/R. If the surround channels need to tap into that power though, it will be there on demand.
    In an ideal situation, a HT setup would use the exact same speakers in every position. Most people can't accommodate a setup like that though, so dedicated(horizontal) center channels were born. This is the same reason that most people will use smaller bookshelves as surrounds.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • nonfilter
    nonfilter Posts: 7
    edited April 2010
    thank you all for answers , BUT !
    Isn't neo 5.1 or 6.1 going to take 2 channel audio and remix it "EQUALLY" across 5.1 or 6.1. Maybee it's not neo but some other dts decoder that does that .
    I am also setting it for movies , but a lot more for games threw my PC!!
    I mean if what you all say is true , so far I see no advantage to have same towers all around . So I need correct info , without me saying you are not correct , if that is possible !
  • comfortablycurt
    edited April 2010
    It doesn't mix it "equally"...that would be all channel stereo, where all the speakers are playing the exact same thing.
    What NEO does, is take a stereo source, and convert it into surround sound. It matrixes in the surround effects. It's not as if all the speakers are playing the same signal. That wouldn't even be surround sound...it would just be a mess of noise.
    Dolby ProLogic does the same thing. It takes any 2 channel source, and matrixes the center/surrounds into the mix.
  • nonfilter
    nonfilter Posts: 7
    edited April 2010
    When I say "equally" , I am referring to the amount of wattage being sent to the speakers , of course it is remixed . Do we understand each other , or do I have to go over there and slap you ( just kidding , you hope!)
  • cheddar
    cheddar Posts: 2,390
    edited April 2010
    Curt already summed it up pretty well when he said a speaker will only send as many watts as needed to a speaker to produce a sound at a certain volume. If you have helicopters warming up in front of you on the screen, most of this sound will come from the front three (L/C/R) because that's 'where' the helos are firing up. More volume means more watts are needed to produce the sound. You may have some 'ambience' sound coming from the surrounds. But those helos are going to be louder than anything else, so more watts.
    Special surround modes won't adjust all volumes equally. So you won't hear the helos all around you. They will still sound like they are coming from up front. So still more watts to those speakers.
  • nonfilter
    nonfilter Posts: 7
    edited April 2010
    What about 3-d positioning in games . You step on that branch behind me its going to sound just as loud as if it happened up front , at least with the right speakers , right?
    what about compressed music decoded to all channels , you might chose stereo remix on the rears also , or different instrument or voices on the rears . Correct me if I am wrong , but lets step away from movies for a second .
    P.S. , and thank you for responses to this point!
  • cheddar
    edited April 2010
    One important aspect of surround sound is directionality. In FPS games, you are usually moving toward some objective. And all the interesting stuff is usually happening on screen, in front of you, drawing you on. So that's where the majority of the sound usually comes from. There's nothing preventing a sound designer from using all channels equally. And sometimes they do use the surrounds very effectively, basically having things attacking you from all over. But to play the whole game this way would be very disorienting as you'd just be spinning around the whole time shooting things with nothing in front of you to drive you forward in the game.
    With music, it's the same thing. They can put you in the audience, a few rows back, which would still have most of the sound in front of you. Or they could drop you into the middle of the stage or orchestra pit. But that's not how most people listen to a show.
  • comfortablycurt
    edited April 2010
    Ok...hypothetically speaking, if someone was walking through the woods on every side of you, and they all stepped on a stick at the same time...yes, it would have the same loudness from every direction.
    But, no, each speaker is not going to be receiving the same wattage at all times. A speaker is only drawing as much power as it needs at any given moment. Each speaker is going to be capable of tapping into the amps full current though, if the material requires it.
    In a situation where you're using all channel stereo...all channels would be receiving the same wattage(assuming that you have the exact same speakers in each position).
    So, I guess the answer to your question is, yes...the surrounds are receiving as much wattage as the fronts.
    As I said above though...95% of the time, your speakers are only going to be drawing a few watts from your amp. They only tap into the amps full current during bigger dynamic transients.
  • nonfilter
    nonfilter Posts: 7
    edited April 2010
    I will continue to research , but at this point given the appreciated input from you guys , I a looking at saving a few bucks on setup . Maybe I'll go to a 7.1 setup .
    thank you all , frank.
  • cheddar
    edited April 2010
    It's all about bang for your buck. You get the most bang for your buck with the front three. And if you've got money to burn, sure it would be great to have the same great speakers in all channels. But when I've watched meters that actually measure the wattage during both music and movies, if the surrounds are getting 1/10th the amount going to the front speakers, they're pretty 'active'. And they can get far less when there isn't much action happening.
  • comfortablycurt
    edited April 2010
    Exactly. Depending on the movie...the surround speakers will be active for a total of 2-3 minutes out of a 2 hour movie. IMO, it's not worth it to stretch your budget to put towers in back. Especially if that means sacrificing a little bit elsewhere in your rig.
  • cheddar
    edited April 2010
    It is pretty bad how few movie tracks try to give the listener a truly immersive surround experience. But there are some nice exceptions. Not saying the surrounds are ever really equal to the fronts in usage, but good sound design can give a more immersive surround experience than just a few good minutes.
  • comfortablycurt
    edited April 2010
    Definitely. In faster paced action movies, the surrounds will be getting a lot of usage.
    In many movies though, that are more storyline based, the surrounds will hardly see any use at all.
    Either way though, a competent pair of bookshelves will easily be able to carry a surround channels sound track. Floorstanders are better...but if it means skimping on other aspects of your system, you're better off going with smaller bookshelves.
    As I said above, in an ideal scenario, each channel will use an identical speaker...but in most situations, it simply isn't practical.
