Vintage Tuner
xfontanax
xfontanax Posts: 82
edited November 2003 in Electronics
I'm looking for a vintage tuner on ebay. I think I prefer the old analog dial, but I'm not opose to digital displays. There are literally hundreds to choose from, can anyone recommend one that would go for less than $150? I'm currently bidding on this:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3057587996&category=3282&rd=1
I know that price won't hold, so any recommendations would be appreciated.
Post edited by xfontanax on
  • rs159
    rs159 Posts: 1,027
    Well, it ain't vintage, but I've heard nothing but good things about the tuning section...http://tivoliaudio.com/pm1cla.htm
    That is, if you don't mind getting up to tune. But I assume that won't bother you since you like analog dials...
    edit - http://www.onhifi.com/product/tivoliaudio_model_one.htm
    "The Model One employs what Tivoli calls "a state-of-the-art, discrete-component FM tuner featuring GaAs MES-FET mixers." GaAs MES-FETs were designed to enable cell-phones and scanning radios to zero in on closely spaced or distant signals, but Tivoli claims to be the first to employ them in a tuner."
    "And it works! I can tune in an astounding number of FM stations here in NYC -- remote NJ college stations and stacked-on-top-of-one-another city stations alike."
    "What's so nice about the Model One is that it does what it's designed to do really well. It sounds good and it picks up stations like crazy. "
    Though it's speaker is mono, the headphone output (on the back, I think, so you wouldn't have a wire in the front) is stereo.
  • bikezappa
    bikezappa Posts: 2,463
    http://www.fmtunerinfo.com/
    This site will keep you busy reading about old but good tuners. They are all analog tuners which are the best.
  • dorokusai
    dorokusai Posts: 25,576
    The NAD 4020 is an outstanding vintage tuner. It comes recommended from Russman, but cap the price at <100.
  • xfontanax
    xfontanax Posts: 82
    Thanks for the input.
    bikezappa, thanks for the link, it has a lot of good info.
  • dorokusai
    Great link BikeZappa, thanks :)
