bass shaker hook-up!
I plan to hook-up 3 bass shakers with a plate amp from a subwoofer. The sub amp will have a L & R output( Stereo), How can I hook-up the 3rd? Use one of the ch. for to bass shakers in series? HELP $ thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
Why not 2, or 4? you may never know the difference, but It will be a different load on the amp on one channel no matter how you hook up an odd number of them.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Thanks for the help, I only have 3 seat in my HTMy HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
I have pretty limited experience with these. They seem to work best when mounted on something solid, heavy. I had them mounted to my couch, good results. Mounted 2 of them to my recliner for sh*ts and giggles, not good.
If you can mount them to something that your theater seats are mounted on, it might be better.
Good luck and have funDodd - Battery Preamp
My theater seats are recliners(3) so may-be I can mount them on the frame thanksMy HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Two ways of doing this. One is to shake your butt in a vertical motion (did I just seriously type that?) and the other is to shake your back in a horizontal motion. I like the back motion personally. One big problem is if your feet touch the floor and the floor is not shaking. Put's an end to the fun.
