bass shaker hook-up!
dholmes
dholmes Posts: 1,136
edited November 2003 in Speakers
I plan to hook-up 3 bass shakers with a plate amp from a subwoofer. The sub amp will have a L & R output( Stereo), How can I hook-up the 3rd? Use one of the ch. for to bass shakers in series? HELP $ thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • hoosier21
    hoosier21 Posts: 4,418
    Why not 2, or 4? you may never know the difference, but It will be a different load on the amp on one channel no matter how you hook up an odd number of them.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • dholmes
    Thanks for the help, I only have 3 seat in my HT
  • hoosier21
    I have pretty limited experience with these. They seem to work best when mounted on something solid, heavy. I had them mounted to my couch, good results. Mounted 2 of them to my recliner for sh*ts and giggles, not good.
    If you can mount them to something that your theater seats are mounted on, it might be better.
    Good luck and have fun
  • dholmes
    My theater seats are recliners(3) so may-be I can mount them on the frame thanks
  • madmax
    madmax Posts: 12,434
    Two ways of doing this. One is to shake your butt in a vertical motion (did I just seriously type that?) and the other is to shake your back in a horizontal motion. I like the back motion personally. One big problem is if your feet touch the floor and the floor is not shaking. Put's an end to the fun.
    madmax
    Vinyl, the final frontier...
  • hoosier21
