Back to the SDA's
Last night I heard my SDA's for the first time in about 7 months.
When I got the LSi9's I tried them for a few days. Then I hooked up the LSi15's and played them for almost 7 months. I had become concerned because I was afraid I had grown to like the SDA sound too much and was thinking maybe the sound was skewed. You know, like when you set an EQ extremely wrong and after a while it sounds good and becomes your reference. I was wrong.
The SDA's totally blew me away... Again. There is no substitute. I ended up listening from about 6:00 to midnight. With the other speakers I was ready to give out after about an hour. The highs were so smooth, the bass was acurate and low, the soundstage wide, the midrange perfect. It was night and day. Polk NEEDS to start making these things again. THERE IS NO SUBSTITUTE!!!
madmax
madmax
Vinyl, the final frontier...
Post edited by madmax on
Cheers,
Russ
I have the SDA-SRS, the SDA-SRS 1.2, the SDA-SRS 2.3, the SDA-1C's and the SDA-CRS+
I also have the LSi-15's, the LSi9's and an LSiC, but not for long...
On a side note, while listening to the LSi's I ended up with a Sony CD 5 disc recorder. While it sounded no different than my Luxman player on the LSi's, it was a world of difference with the SDA's. If it didn't record CD's it would be gone as well.
Just want to say that although the LSi's are great for the price not to mention for multi-channel, they do not compare to the SDA's for two channel listening in my opinion. I would also say the LSi's are easier to set up and not as room dependent as well.
BTW, another evening is gone and all I did was to listen to the SDA's. That has not happened for the past 7 months. C'mon Polk, lets get some new SDA's out there. I gave the current offerings a real chance here (7 months) for 2 channel listening. I'm just saying that some of us are still looking for SDA quality, not putting down the benifits of the LSi series.
madmax
madmax
I own the 2B's (on loan to my father). You have to feed them power, 200wpc min. When I was demoing the 2B's back in '89, I did so against the KG4's and I don't think they are anything alike. The KG4's screamed at me, the Polk's sang.The only thing the KG4's had going for them was the bass and it was really too much, boomy I would say. Bottom line, I never thought the 2B's sounded tinny, but they are not as full as the bigger SDA's.
I always go back to SDA's....at F1's house
I have not heard the 2B's but I know what the CRS's sound like. Actually they (the CRS's) can sound as big as the big dogs with a little less lower midbass and bass if they are in the proper room. With a sub and a smaller room you may not be able to tell the difference unless you do a direct comparison. Of course it depends on everything!
madmax
I found the 2b's to be very rich, full, and had a adequate low end. You'll have to look up my review to see the gear it was paired with.
That being said, my SRS 2's simply floor me EVERY time I listen to them. The new tube pre-amp has made the soundstage even larger and more airy than it was, and the bass has ALWAYS been DEEP and full. I almost think I'm becoming spoiled by the low-end on these things.
Cheers,
Russ
I would like to eventually like to get a large pair of SDA's but the wife will only let me spend so much money at a time.
I used to own Sda 2b's and I thought my newer speakers at the time(rt1000ps) blew them away.
I feel the Lsi series is light years ahead of the SDA speakers of the past.There tweeters where so damn bright.
They sound great with some recording but most they are way to bright.
All a matter of opnion
The Lsi15's are a remarkable speaker when you connect them to great gear.That goes without saying.Like Max said about the EQ....I feel thats most people.Most people are not used to hearing things flat or natural.Colored or to the extreme is what most look for.Still it's your/our hobby and we shall all hear as we please.....
Now I need to go find a damn sub.
Dan
I don't think 2B's on a receiver really show off the SDA line, but as you say, "As we all know speakers are very personal".
They each have their strengths and weaknesses, SDA has a better total score in my book, LSi does for others. Fact is, they are both fine speakers.
Jesse, the more people buy the LSi, the less are fighting us for SDA...works for me.
Cheers,
Russ
2005-06 Club Polk Football Pool Champion!!
Hmmmmm.....let's see, the SL3000 tweeter is dead flat from one end to the other, these monsters pump out bass down to either 12Hz (2.3TL) or 10Hz (1.2TL) and at 25Hz are cleaner than most amps. You can't say that about the LSi's, so which ones are light years ahead???
Hello I ran the SDA 2b's off a B&K st140 amp.I used a Denon avr3801 and before that a Pioneer Elite vsx26tx as a preamp to do so.In my opnion I felt the rt1000ps where a better sounding speaker with more detail and clearer mid range.Both speakers where bright but the SDA's where harsher..if thats a word...but get my meaning you will.I gave my SDA's to my uncle and now they sit in his closet as he now owns my rt1000p's and also feels that they are a better sounding speaker.Like it or not.
So don't get offended when my personal tastes for SDA is lesser then RT and now Lsi...They all where my speakers and I feel the way I do.I will say that the SDA's are a nice sounding speaker but I feel you can do better.I did twice.
In my opnion the Lsi 15's are the very best sounding speaker Polk ever designed that I have had the pleasure to listen to or own.I have heard almost every single model.I don't own them to be cool or in.I own them because I feel they are the best for me right now.Down the road I'm sure I will show them the curb.But not today.
If your feeling don't line up with mine...thats fine F1 but don't come out hard and not expect a reaction from me.I'll take it lightly here but come at me and I will convert into old mantis and unleash furious anger apon you.
I'm into what I'm into and thats that.
Liking Lsi and rt over SDA Mantis
Come out hard? Are you joking?
I presented facts from Polk's own specs and a opinion. No personal attack.
You presented an opinion, no facts and a personal attack. Who is the one that got offended??? Sure wasn't me. :rolleyes:
Here we go again.....
Your opnion my opnion..........
Here we go again????
Har
LOL thats funny.
SRT over the LSI's????not here
A little Zen for you........Those that don't know, don't know that they don't know.
Have a nice day,
Jesse
Jesse,
Go easy or the mantis-san will fill your email box full of obscenity laced tripe. Man, I wish I had one of those emails to post, the entertainment value was astronomical....
BDT
*****edited out per chuck's request********
but it was still pretty funny.
BDT
Great cooperation!
madmax
