DIY Dodd Tube Buffer Kit
george daniel
Post edited by george daniel on
ELP part deux?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I am getting one of these to pair with a modified CD/SACD/DVD player and GR-Research N2x speakers. Now I just need to figure out an Amp.HT: Ninja Master LSi9s, Ninja Master LSiC, Slightly Modded LSiFXs, Modded LSi7s, Outlaw LFM-1 EX and Polk PSW125
Outlaw 970 Preamp, Outlaw 7700 Amp, Velodyne SMS-1, Oppo BDP-83,
2 APC H-15s and a Panamax 5400 for good measure
Stereo: DIY Alix Music Server, DODD Audio Battery Tube Buffer, Modded DAC-60 and MF V-Link (for now), DIY Silver ICs, Battery Powered Class D SDS-254 Amp, and GR-Research N2X Speakers -
good on you,,please keep us posted, as in a "build thread" if you would.Thank you kindly--good luck--georgeJC approves....he told me so. (F-1 nut)
I will. I will also compare the Ninja modded LSI-9s to the N2Xs once I have built the N2Xs.HT: Ninja Master LSi9s, Ninja Master LSiC, Slightly Modded LSiFXs, Modded LSi7s, Outlaw LFM-1 EX and Polk PSW125
I love DIY build threads with lots of pictures! The Adcom D/A was killer, a friend of mine did that one, following the thread, and he's blown over. Uses a vintage Pioneer transport that's built like a tank.
Any recommendations on a DIY Amp?HT: Ninja Master LSi9s, Ninja Master LSiC, Slightly Modded LSiFXs, Modded LSi7s, Outlaw LFM-1 EX and Polk PSW125
Been thinking about picking one of these up to mess around with in the office rig; allows you to use KT88, KT66, EL34 (6CA7)or 6L6G
http://www.vkmusic.ca/TU-879S.htm
http://www.vkmusic.ca/TU-879S_point.htm
http://www.6moons.com/audioreviews/elekit/6L6.html
http://www.positive-feedback.com/Issue45/elkit.htm
H9, would you power your 1Cs with these amps ?Speakers: SDA-1C (most all the goodies)
No, not enough power or reserve's. It could be done, but for lower level listening only. Not that a nice beefy, well built SE lower watt per channel tube amp couldn't power them. It's just the above kit I don;t think would do a great job, IMO.
Thanks, that is what I thought but just checking.
I would be nice to have a say a 40wpc tube DIY amp.Speakers: SDA-1C (most all the goodies)
Tracy,, you need to buy one and start a thread
JC approves....he told me so. (F-1 nut) -
George, who sells a beefy enough tube DIY amp for the 1Cs ?
Or were you referring to the Dodd pre ? If so I am plenty happy with the Wright;):DSpeakers: SDA-1C (most all the goodies)
