What is RTA?
Hello. I recently purchased a used RTA 11TL (tower speakers) and would like to know more about it. I could not find it in the PolkAudio website.
Also, when I press on the woofers, the other speakers seems to move with it. Is this normal? Is this what makes it RTA? I would appreciate any information. Thanks.
Post edited by sid700 on
Welcome to the forum.
RTA stands for Real Time Array and the TL stands for Tri-Laminate, which refers to the three layers of material used in the tweeter. Yes, it's normal for the other mid-drivers to move. You've got a nice speaker, enjoy.Political Correctness'.........defined
President of Club Polk -
The woofers have no electrical signal being sent to them. They are activated by the mids movement back and forth, as they "pressurize" the speaker cabinet. Every other speaker company calls it a passive radiator. Polk called the technology "fluid-coupling" which would lead someone to believe there was some kind of exotic water line in the speaker. The "fluid" in the coupling, is nothing more than the air in the speaker cabinet. As we all know, the air around us DOES contain a certain amount of water, or humidity. Great little marketing thingy huh? I'd say it was the closest Polk ever came to a Blose type marketing tactic. Crafty. You have an okay sounding pair of speakers there Sid (I've had 4 pair of those already), that appear to be functioning just fine.
George Grand (of the Jersey Grand's) -
Air is a fluid; as is water.
The difference in them being that air is a gas and water is a liquid.
It is perfectly correct to call it a fluid-coupling. -
Well butter my butt and call me a biscuit, you don't say?
Milliseconds of genius here.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
I am not going any where near your BUTT , however I will call ya biscuit.
BISCUIT!Front
Polk RT800i (BI-wired)
Rear
Polk RT600i
Center
Polk CS400i (BI-wired)
Sub
SVS 25-31PCi (22Hz tuning port)... it's SubHuman
Receiver
YAMAHA RX-V1400
TV
Mitsubishi WT-46807 HDTV
HD receiver
T i V o HR10-250 -
This friggen forum never stops making me howl:D
!/4 Twin***WAREMTAE*** -
Thank you Andrew. I'll have to jot that down and put it in my notes.......... as a great marketing thingy.
I hope this is the info you would like to know.
The RTA 11TL
Specifications:
speaker uses a single 1" dome tweeter,
two 6.5" drivers and
two 8" bass radiators.
The frequency response is from
22 Hz to 26 kHz with the
-3dB limits of 36 Hz to 25 kHz
Power handling is 250 watts/channel
the Impedance is compatible with 8 ohm outputs and the efficiency is 90 dB.
Enjoy your RTA's;)
Har -
Thanks everyone. I got the info I needed. I feel better now that I don't really hear a good thumping coming out of the "passive radiators." I thought these woofers that were out of whack.
Oh...I was just thinking, has anyone tried replacing one of the passive radiotors with a wired woofer? I've never looked into making my own speakers, but from what I can gather, I figured I can buy a low frequency crossover, a woofer and maybe a binding post. I secure the crossover in the speaker and attach the wires accordingly to the post and the woofer. The speaker then will be bi-wired (or is it bi-amp?) and I'll get more bass. Will this idea work or will the result be so sonically gross that it's not worth pursueing? -
Leave it alone. A tweek like that will be VERY involved, and the end result will more often than not be a fubared RTA11.
Cheers,
Leave them alone! Polk had a great idea with those PR's. If you need more natural bass then get a clean high current power amp and some high-end interconnects/speaker cables, just not Monster.Political Correctness'.........defined
ROFL... he should have left off the liquid/gas part. He was doing well til that spilled out. Though he's correct in saying air is a fluid (to an engineer anyways).Denon 3802
B&K 7270
Outlaw ICBM
Behringer DSP1124P
Samson S1000
SVS 20-39CS+ (x2)
RTi150's
CSi40
FXi30's
RTi38's
Win Vista HTPC
InFocus 4805 ~100" Screen -
I have a mechanical engineering degree. Looking back, I guess it was funny. Just wanted to give him a bit of knowledge.
Dont sweat it andrew... I'm an ME as well and know what you were saying.Denon 3802
B&K 7270
Outlaw ICBM
Behringer DSP1124P
Samson S1000
SVS 20-39CS+ (x2)
RTi150's
CSi40
FXi30's
RTi38's
Win Vista HTPC
I do not possess an ME, and I understood what Andrew said, and know it to be true. I'm going to go out on a limb, and say that a good majority of the people going into the store, WOULD NOT know that "fluid-coupling" was nothing more than a term for a passive radiator based design. I SINCERELY doubt most of the salesman involved in marketing those speakers when they were available would have been able to explain "fluid coupling" had they not spoken to Andrew, yourself, or of course, me. Marketing tool boys, and it doesn't make for a bad pair of speakers.
Hello. Can anyone tell me the frequency range of the mids in the RTA-11TL (i.e. MW6510)?
How about the tweeters?
Thanks in advance.
