Monitor 10 series 2 tweeter
aloutah
aloutah Posts: 241
edited April 2010 in Vintage Speakers
What tweeter does the monitor 10 series 2 use? Is there an original and a replacement part?
Post edited by aloutah on
  • nadams
    nadams Posts: 5,877
    edited April 2010
    Mine had SL2500's. Not sure about replacements, never had to replace any. Call Polk CS and see if they're still available.
    Ludicrous gibs!
  • aloutah
    aloutah Posts: 241
    edited April 2010
    I bought a pair of monitor 10 series 2 recently. The guy i bought them from said he had blown the tweeters and had them replaced. I havent opened them up yet, and was just curious what the proper and/or replacement tweeters were.
  • seeclear
    seeclear Posts: 1,244
    edited April 2010
    Take the tweeters out (it is easy; just unscrew 4 screws carefully) and see what they say on the back. Then call Polk CS at 800-377-POLK and tell the nice people there that you are a member of Club Polk and they will help you right out, and the last time I did that it was 20% off and free shipping (but they do charge tax in all 50 states, I believe).
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • DollarDave
    DollarDave Posts: 2,575
    edited April 2010
    I would jot the serial numbers down and have them ready for Polk CS to look up the correct tweeters. The other fella may not have replaced them with the proper parts.
  • nadams
    nadams Posts: 5,877
    edited April 2010
    aloutah wrote: »
    The Monitor 10 Series II's were the last run of the Monitor 10's. My original drivers were all dated 1991, and the tweeters were the SL2500's as stated before. I don't know if Polk has replaced them with a different part number in the meantime, like they did for the SL2000's.
    They looked like this -
    Note the foam ring around the tweeter.
    Ludicrous gibs!
    heiney9 Posts: 25,503
    edited April 2010
    Series II Monitors used the sl2500 originally, very similar to the sl3000.
    IIRC, the RD0198-1 is the correct replacement part.
  • agfrost
    agfrost Posts: 2,474
    edited April 2010
    heiney9 wrote: »
    This is correct.
    Jay
  • aloutah
    aloutah Posts: 241
    edited April 2010
    Thanks, I just havent had the time to check, and knew there are some very knowledgeable people on this forum. I just wanted to make sure he hadnt replaced them with the wrong part.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2010
    heiney9 wrote: »
    That.^^^
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • aloutah
    aloutah Posts: 241
    edited April 2010
    Curt what are you referring to with your post of "that.^^^"?
  • nadams
    nadams Posts: 5,877
    edited April 2010
    He's essentially saying that heiney9 was correct in what he was saying.
    Ludicrous gibs!
  • aloutah
    aloutah Posts: 241
    edited April 2010
    nadams wrote: »
    He's essentially saying that heiney9 was correct in what he was saying.[/QUOTE
    Just curious. Thanks
