Re: RTi or CSi?
ditcin
ditcin Posts: 3
edited November 2003 in Speakers
I currently have the RM7600 w/sub as a home theatre set-up -along with a 15inch cerwin-vega sub and two additional Polk RM7600 sats for the 6.1 rears.
Now, would it be better if I switch over to RTi8 for all six speakers (including the rears) for my system? Having them floor level is not a problem - besides, I can always make a "cube" stand to raise the surrounds and rear if I choose to.
Oh, and if I do the above I'd upgrade the center with the CSi5.
Any opinion?
Thanks,
Scott
Post edited by ditcin on
  • dorokusai
    dorokusai Posts: 25,576
    Upgrading to that series is a worthy cause. You will immediately see how much the RM7600 is lacking if you do go that route.
  • ditcin
    ditcin Posts: 3
    Really. Wow. sounds good. I figured it was a bit of over-kill. Thanks for your response.
