Thinking of Scrapping my rig...
nooshinjohn
nooshinjohn Posts: 25,916
edited April 2010 in Electronics
And starting over. While I am pleased overall with it's performance, I cannot help but think if I were to focus specifically on two-channel, I could bring my setup to a level I previously thought would be unobtainable. If I were to sell off my current setup, I would be able to get about 7500.00 back in play for a better rig. I wave already begun to sell of much of my Franklin/Danbury mint collection, so I will have about 10k to play with on a two channel setup.
Keeping in mind what I already have in my sig and what may be useable in a new set-up, what would you guys recommend I do. What should stay and what should go? What can be upgraded or improved and what new gear would you suggest?
As always, I am open to high quality used gear as well.
Post edited by nooshinjohn on
«13
  • Conradicles
    Conradicles Posts: 6,342
    edited April 2010
    It is always fun to start over and try out new gear. Sounds like you would have a really nice budget to play with as well. From the old Nike ad...Just do it.
  • AudioGenics
    AudioGenics Posts: 2,567
    edited April 2010
    We'll be waiting for the pictures of the "new" system !
  • hearingimpared
    hearingimpared Posts: 21,136
    edited April 2010
    Very interesting John. Perhaps you might consider going with a really good high powered, high current hybrid, integrated amp.
    http://www.audiogon.com/cgi-bin/cls.pl?intatran&1275526950&/Musical-Fidelity-KW-500-No-Com
    http://www.audiogon.com/cgi-bin/cls.pl?intatran&1275165127&/Musical-Fidelity-Trivista-300-
    You can get the Trivista much cheaper. I have the TriVista 300 and I love it, but would buy the kw500 in a heartbeat if I had the money. I heard it at Jesse's and it is awesome.
    edited April 2010
  • Face
    Face Posts: 14,340
    edited April 2010
    I would decide on a pair of speakers first, then work from there.
    mhardy6647 Posts: 35,005
    edited April 2010
    The Stingray is excellent; I'd expect that the Snappers are, too. The Manley amplifiers are well-made and reasonably priced.
  • Ricardo
    Ricardo Posts: 10,636
    edited April 2010
    Good luck. If you want to start over, there is no "packaged good sounding two channel system". You'll have to go through trial, matching, swapping and lots of time to get there. Maybe you should think of what you don't like in your system and start from there. If you're satisfied as you say you are, just stay where you are. It will be cheaper and less frustrating.
    SOPA
  • SolidSqual
    SolidSqual Posts: 5,218
    edited April 2010
    Find your speakers first John.
  • vc69
    vc69 Posts: 2,500
    edited April 2010
    No first hand listening experience but I would love to try any of the Manley stuff. I hear it's the bee's kneez.
    I also concur with picking out your speakers first. Are you going to stick with the 2.3TL's?
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
    edited April 2010
    I am considering that. I do love the SDA sound, but my leanings of late have me thinking about Magnepans. I am looking for elegance as well as performance. My intent for now is to keep my turntable and other source components, so I am looking for a dedicated SACD player, amp/amps, preamp and speakers (maybe). If upgrading to RDO's and the crossovers make a dramaitic improvement to the TL's, I may just keep them. The advantage of keeping them will allow me to spend a bit more on the other stuff.
  • Face
    Face Posts: 14,340
    edited April 2010
    Depending on the components used, it can be far from subtle.
    edited April 2010
    One thing my current setup lacks is focus. While the sound is very good, with the expected wide and deep soundstage, the imaging itself tends to be rather vague and unfocused. The original SL3000's are good, but become harsh and overpowering at modest to loud volumes.
    edited April 2010
    Theater horns and single-ended triode amplification.
  • Face
    Face Posts: 14,340
    edited April 2010
    Upgrade your crossovers and get a real source.
  • vc69
    vc69 Posts: 2,500
    edited April 2010
    If I were you John, I would consider doing the xover/tweeter upgrade first and foremost. That way you can determine whether or not you want to keep the 2.3TL's and build around them. Obviously I have no first hand experience with SDA's but if you like them, why not work with what you have and put some really good stuff in front of them to see if they will meet your needs. I wholeheartedly agree that you should pick your speakers and then build to suit them. Synergy and all of that... ya know?
    While the Sunfire stuff is good, there is a whole other world of sound out there that isn't Carver. My TFM35x is going to be in the FM very soon. I have a surprise on it's way at this very moment. :)
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • hearingimpared
    edited April 2010
    I agree with the crossovers first John. Sonic Caps & Mills resistors will make a marked improvement in your SQ. RD0198s next, then spike them with MYE Sound spikes, Dynamat your MW baskets and Mortite your drivers and tweeters . . . you will think you bought brand new speakers.
    BTW the Manley Stingray is awesome sounding. I heard it at Ted's Polk Fest driving a pair of 1Cs. I believe Mike (Face) has it now but I don't know what speakers he is driving.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited April 2010
    I wouldn't touch the maggie's unless your planing on hooking up a sub . If you dont care about others listening to your rig then I would go for martin logans
    Martin logan look like fine art sculpture's and have that high end look and demo room sound . The sweetspot is so small with these speakers but once your in it your in the music . I love the sound of planars unrestricted vocal reproductive speed an clarity
    If accuracy is important then planars are the only way to truly reproduce sound
    I persnaly think that the upgrade is most noticeable when you add new speakers
    Maybe get the new speakers first instead of dumping the electronics then you can buy the electronics around the new speakers?
  • SolidSqual
    edited April 2010
    John, if you want imaging and soundstage with laser guided missile focus, check out my Emerald Physics speakers. Plus, you also get the boxless sound of the maggies. I'll have my new ones in a few weeks. Stop by and have a listen.
    I see the Emmys being great for you given your impulse blow the doors off any at max volume.
  • concealer404
    concealer404 Posts: 7,440
    edited April 2010
    SolidSqual wrote: »
    :eek::p
    "Sure! Turn it ALL THE WAY UP!!!"
  • cstmar01
    cstmar01 Posts: 4,424
    edited April 2010
    If I were you I would just go and get the CV 215's. Those are the best speakers in the world. JK
    Good luck with everything. Its always fun to start over but can be super hard at the same time. After hearing the maggies they are great, however I'm not super found of the super tiny sweet spot with them that I experienced.
    Toolfan66 Posts: 18,048
    edited April 2010
    I think your insane John!!! Follow the advice above from Mike and Joe.
  • lightman1
    lightman1 Posts: 10,796
    edited April 2010
    Don't make me drive up there, John.
    edited April 2010
    lightman1 wrote: »
    Go and I will help pay for the trip, all I ask is you give him a swift kick in the **** for me...;)
    edited April 2010
    Come on guys... I dare both of you to show up. I can take you both at the same time!!!:p;):D
    I am grateful for all the help so far. I have decided to begin by going through the Polks and doing the upgrades first. The next thing will be introducing TUBES into the mix for them. I am working on that aspect now as we speak, so stay tuned.
    Tony M Posts: 11,616
    edited April 2010
    John...see if there's any maggies around you. Put a want ad in craigs list and see what turns up.
  • lightman1
    edited April 2010
    You got it, Larry!
    I PM you my paypal and set out at first light.:D
  • lightman1
    edited April 2010
    TUBES
    Tubes? Do tell!
    F1nut Posts: 51,761
    edited April 2010
    Face wrote: »
    Exactly what I would suggest.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2010
    Personally, I'd start with upgrading your CDP. Are you using the Sony or the Yamaha as a 2 channel source?
    Either way, neither of those players seem to be anything too special from a SQ perspective. Having a better source can make a TREMENDOUS difference in your sound. I got some very big improvements in the overall sound of my rig when I upgraded to my Denon 2910...and the improvements went even farther when I added my DAC. A source would probably be the best place to start.
    After that, I'd recommend doing XO upgrades/RD0-198's, as others have suggested. I haven't updated any of the XO's in my speakers yet, but from everything I've ever read/heard, the XO mods can make your SDA's sound like a new pair of speakers.
    I'm planning on doing the Mortite and Dynamat mods to both my 7A's and 2A's sometime in the next couple weeks or so.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
    edited April 2010
    I have the Yamaha PX-3 as my main source and the Carver SDA-490t as my main CDP, and I have no real desire to dump the turntable. I have thought of doing a bit of upgrading the tubes in the CDP to se if I could get more out of it. Any suggestions on that one?
